Rust in all the worst places... :(
Old Aug 9, 2002 | 10:39 AM
nj88v6's Avatar
Ok guys, I need some help... I am starting to find some rust, and in the worst place. I have rust on the rear of the hatch where the bolts are to connect the spoiler.
I don't know what I should do about this, it seems like eventually I may be able to pull the spoiler right off
I also have rust in the t-rails. If I replace these, what should I do to prevent further rust?
Old Aug 9, 2002 | 12:11 PM
2vmodular's Avatar
http://www.geocities.com/goodytommy/rust/
Old Aug 11, 2002 | 04:10 PM
jawzforlife1's Avatar
try cutting a stripe of meatal, drill a hole through it and but the spolier bolt through that hole. That will keep the spolier on but not stop the rust.
Old Aug 11, 2002 | 05:15 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Sand the rust a little, and POR-15 it.
www.por-15.com
Old Aug 11, 2002 | 09:29 PM
2vmodular's Avatar
por-15 encapsulates the rust. it does not remove or other wise alter the structure of it.
my preference is either to sandblast or etch the surface with phosphoric acid, then apply the coating.
Old Aug 11, 2002 | 10:53 PM
nj88v6's Avatar
Damn rust
Well, the rust on this part seems to actually be eating and bubbling up the inside, unde the paint. I can only assume that watergot in from under the sppoiler, through the bolt openings themselves. I t is rusintg aorund those rubber stoppers or whatever they are. I might have to opt for a new hatch. Considering that my defrost lines are also screwed up due to a poor tinit job, that might be a good option, if I can find one in decent shape.
Old Aug 11, 2002 | 11:39 PM
Tonyrodz's Avatar
Transmission: auto
Depending on what year you have I have a nice 86 black hatch w/defrost from my Trans Am--in black. I'm right over the border off 80 in Pa.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
