how do i get to the 90-92 guages
Old Aug 14, 2002 | 09:53 PM
killer305's Avatar
i am planning on doing a do it yourself white face gauge installation and was wondering if anyone could tell me how to get to the gauges. thanks
Old Aug 15, 2002 | 12:49 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Pull the black trim off (I forgot if theres any screws to it) then you'll see the rest of the screws you need to remove. Try a search, I remember when I did mine I found in depth instructions in a search.
Old Aug 15, 2002 | 01:16 AM
CrazyHawaiian's Avatar
Car: too many ...
Trying to remember from when i swapped a 145 speedo cluster into my 90 RS with the 110 cluster. All you gotta do is unscrew and pull. You have a pre91-92 so you still have the cable driven speedo, so you'll need to disconect that from under the dash before you pull. You need a screwdriver with a torx set. There are 4-6 torx screws holding the front plate. You remove those and the front black cover plate will come off. There there is a plastic plate that goes behind it that will come off. When u pull that the turn signal pieces will come out (green circular plastic pieces about as big as a quarter). Then you look @ the actual cluster (it will be white with all kinds of holes and alcoves to hide screws). There are 4-6 screws that actually attach it to the dash. I forget the sizes (not phillips or flat, they are rachet) You need to unscrew all of them and it will pop out. Dont remember exactly where they are but if it wont come out then there are still more. Then be sure to disconnect the speedo cable and yank it. Helps if you have tilt steering and can move the wheel away.
sheachopper
Jul 31, 2019 11:27 AM
