guage cluster swap!
guage cluster swap!
i wont to know if anyone has swapped a late 80's style camaro guage cluster with a 91 or 92 camro cluster ? is it possible? is a direct replacement ...... everything hook up right? tanx let me know
Try a search next time first. always the best way to find info as alot of these questions have been asked before. But the short answer is No, they wont bolt up. The 91-92 Clusters are electronic and use VSS to get the info for the speedo. The clusters you want to look for are from 90 and earlier IROC's and Z28's that goto 145 mph and are cable speedo driven. Those should bolt up with minimal problems but I've never tried in a early 80's .. only a 90 so I'm not sure if it'll work sorry (did the 145 swap into my 90 RS).
