HEAD liner
Old Sep 14, 2002 | 10:38 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
HEAD liner
I read the technical article on Headliner Repair and have a few questions. I hear that the 3M Spray Adhesive isn't very good, are there other options for glue. It says to get the head liner material at Jo-ann Fabrics is that a national chain and how does the "flame red" color match up??
Any other tips?
:hail:
Old Sep 15, 2002 | 12:20 PM
ZRated85355's Avatar
I also want to know how to get the headliner to stick. I tried using the 3m headliner adhesive and it wosent worth the 10 bucks a can. I made sure everything was real clean and put tons of glue on it and it only held up for about 2 days.
If anyone has succesfully made there headliner stick i would appreciate there sugestions.
dave
Old Sep 15, 2002 | 01:46 PM
Tony86TA's Avatar
Make sure you spray both sides of what you are glueing. Let it set up and get tacky. Then put both pcs together. Make sure you do not spray to much on backing. It will come through the cloth.
Old Sep 15, 2002 | 09:15 PM
How long has yours stayed up!!
Old Sep 15, 2002 | 11:14 PM
bj350hp's Avatar
Car: 1987 Camaro SC
also Let it dry for 24hr befor puting it back in the car, thats what i did with mine and its been Fine for the past 3 months now
Old Sep 15, 2002 | 11:21 PM
justinhebert's Avatar
Ive used multiple 3m adhesives. They dont hold up to the much heat. I had a local upholstory shop do it for $50 (material included) He used a water based glue. It looks like new.
Old Sep 15, 2002 | 11:23 PM
how did the color match up,, what color did you use??
Old Sep 16, 2002 | 08:59 PM
Tony86TA's Avatar
I did one on my 86 T-top and 88 GTA hardtop. No problems. I think the key is to take your time. Before you start make sure you alot yourself enough time as not to rush. Remember, upolstery shops are professionals and know all the little tricks.
Old Sep 16, 2002 | 10:05 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I've had mine up for about a year now... used the 3M Interior Adhesive in the white can w/ red letters. Paid $10 for it and I still have a lot left. Just make sure you use a lot of the stuff and cover every inch of new headliner.
Old Sep 17, 2002 | 09:01 PM
FastKitteN's Avatar
Car: 1988 Camaro
Engine: 5.7liter v8 (LT1 carb)
Transmission: th-350 rebuilt with a 2400-2800 stall
Not sure if its much different but I went to Napa and got the spray stuff to lay my padding and carpet down and it works great.
Old Sep 17, 2002 | 09:12 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I used Permatex spray adhesive. Works great.
:hail:IROC-Z
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
SlowAZ28
Sep 2, 2015 05:19 AM
z28guy134
Sep 1, 2015 11:50 PM
