T-top repair, what to use and where?
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
The rubber is not broken up or damaged (low mi t/a), but i get a few single drips on each side between the driver/pass window and tops.
what kinda silicone do i buy and what do i look for to know where to put it?
thanks for the help y'all.
You can buy 3M weatherstripping adhesive and use that if your seals are coming up anywhere, but more than likely that isn't going to do you anygood. Your seals are probably worn out from being pressed down for so many years, that they're probably flat now. You'll end up having to replace them.
Mathius
Mathius
i hasd that prob
my 84 z h.o. had that problem...i just puty a thin coat of vaseline on the weatherstripping,and that took care if it.However,i didnt take off my t-tops all the time...if you took em off every day that wouldnt be a good solution because you would have grease prints all over them
D
D Thread
Thirdgen89GTA
Nov 26, 2015 11:04 PM
