Steering wheel loose
Old Sep 16, 2002 | 10:53 PM
86IROC350NY's Avatar
I have a loose steering wheel. Do I need a new steering column? The column is from a firebird and it is coming loose (OFF) right after the long 5 inch plastic adapter looking thingey. I have a new grant wheel and adapter kit not installed yet. Will the problem be fixed once I install it?
It has gotten to the point that I need to lift the wheel/column up a bit in order to turn my brights on/off.
DAMN TILT COLUMNS!!!
If I need a new column how much am I lookin at?
Old Sep 17, 2002 | 06:37 AM
scauffiel's Avatar
There are five (IIRC) bolts deep in there holding that all tightly together; in your case they've loosened up. Prepare yourself for an afternoon of suck. Take notes, sketch diagrams, and get a buddy. You can probably find more info doing a search.
S.
Old Sep 17, 2002 | 06:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
4 bolts actually. My first time in the steering column was frustrating. You'll need a slide hammer to pull out the pins at the base of the tilt. You'll need a puller to get the wheel off, and you'll have to screw around with the ring holding the column lock plate in place. Everything else is more or less a matter of unbolting it.
Old Sep 17, 2002 | 07:06 PM
JF023's Avatar
i had the exact same problem on my 86 IROC after i bought it. i could practically hand the steering wheel to the passenger to drive. at the time i worked at a auto repair shop, so i paid some guy 50 bucks, and he tightened the bolts, and even replaced the bearings.....but it may cost a bit more for you, it is a 3 hour job.
Old Sep 17, 2002 | 08:24 PM
Tony86TA's Avatar
Paid about 200.00 bucks to have it done at the Pontiac Dealership about 4 or 5 months ago. If I had more time I would have tryed it myself, however I neither the tools or the time.
Old Sep 20, 2002 | 02:49 PM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
ok im having the same problem on my 88 bird, how do you get to the area your talking about? do i need to remove the steering wheel? and is it still safe to drive the car this way? (no loss of steering)
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
