Seat Swaps
Old Oct 1, 2002 | 01:12 PM
AliHawk's Avatar
Seat Swaps
4th Gen Seats are beautiful. Personally I think they are prettier than 3rd Gen's and more comfortable too.
I've seen many 3rd Gen's with 4th Gen seats (Camaro's and TRANS-AM's)
Ok my question in here what if you had an electric seat in your 3rd Gen, but the 4th Gen you want to swap to is not electric? Will you lose that option? What about the exact opposite? And what if both were electric, is it easy to let the new seat works?
If anyone made this to his F-Body or have pics I would be thankful if he would post them.
Thanks.
Old Oct 1, 2002 | 02:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Is it possible to simply swap the 4th gen seat on to the 3rd gen electric track (I have no personal experience with 4th gen seats, but my suggestion will work with 3rd gen seats)?
JamesC
Old Oct 4, 2002 | 03:32 PM
AliHawk's Avatar
Thanks man.
Do anyone have pictures of 3rd Gens with 4th Gen seats in?
Old Oct 5, 2002 | 06:50 AM
Z28DJP1987's Avatar
Pictures are not the greatest, but you get the idea. Seats wemt in with no problems.
Old Oct 7, 2002 | 02:57 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
My thirdgen with 4th gens in it.
Old Oct 7, 2002 | 03:19 AM
Saywhut's Avatar
Pics you can get. Answers are another story, but I figure the two seats are so close, and the 4thgen tracks bolt right in to a 3rdgen, it's very possible you could mount the 4thgen seats to the 3rdgen tracks with little or no modification needed. Let ys know if you try it.
Old Oct 7, 2002 | 04:22 AM
Car: 1987 IROC Z
No modifications are needed for 4th gen seats. They bolt straight in.
Old Oct 7, 2002 | 08:03 AM
Z28DJP1987's Avatar
Thats right unbolt a total of (12) fasteners and do the same to install them. You will spend more time cleaning the carpet under the old seats then installing the 4th gen ones.
Old Oct 7, 2002 | 12:10 PM
AliHawk's Avatar
Thank you guys for the great pictures.
omnipotentgoku your Camaro is so beatiful.
Old Oct 7, 2002 | 12:50 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Yes it is possible to bolt the 4th gen manual seats up to the 3rd gen power seat tracks....I did exactly that, it was all a direct bolt up except for the seat controls....one of these days I will fabv up a bracket to mount it under the front of the seat, right now it just sits on the floor under the seat
Old Oct 7, 2002 | 01:22 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
4th gen seats in my 92 RS
Old Oct 7, 2002 | 01:54 PM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
93 Camaro buckets in my 1984 Firebird....
Old Oct 7, 2002 | 02:09 PM
AliHawk's Avatar
Thank you guys for the great pics, I'm planning on doing that to my future 3rd Gen Trans Am if he didn't have leather seats. Only was wondering about the electric movment of the seat.
Old Oct 7, 2002 | 09:05 PM
Car: 1987 IROC Z
thx
Old Oct 7, 2002 | 09:06 PM
Car: 1987 IROC Z
I have an electric drivers side seat as well, no problems with movement at all. Should be a flawless transfer.
Old Oct 7, 2002 | 11:09 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
I'll expand a little on my previous answer.
The seat tracks are held to the seats by 4 bolts on each (13mm I think, same as the ones that bolt the track to the floor. The manual passenger track is easy to get off. The power drivers track is a little trickier...there is a piece of trim that is attached to the track on each side, I think there are three or four phillips screws holding it on, look real close to find them. Even with those out of the way you may need to move the seat up or back undo two bolts, plug it back in and move it the other way and undo the other two. I did the job with a short socket, 3" extension, and an open end. The seat control is held to the seat trim by 2 screws, and I believe that trim piece is also held on by two screws, youll need to remove the trim then remove the switch from the trim. LIke I said the seat tracks bolt directly to the 4th gen seats with no clearance or bolt spacing issues, just remember you may have to power the seat up so you can move it to get at the bolts. My seats fit perfect and work great....just gotta fab up a mount for the switch is all.
Old Oct 8, 2002 | 06:35 AM
Z28DJP1987's Avatar
14mm is the correct size for the fasteners not 13mm.
Old Oct 8, 2002 | 12:48 PM
AliHawk's Avatar
Thanks IROCmonkey.
Old Dec 7, 2011 | 07:35 AM
cdoyle's Avatar
Re: Seat Swaps
This is such an old thread, but I had a question about the switches. How did you mount the 3rd gen switches to the 4th Gen seats.
I'm just wondering if they attach to the seat and look OEM?
Or if I should just stick with looking for 4th Gen seats that are already power.
Thanks!
Old Dec 8, 2011 | 08:49 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: Seat Swaps
I have seats out of a Crossfire SRT-6 and I welded tabs on them to bolt them up. their are both electric and heated (not hooked up) and I had to run wires under the carpet to get the passenger seat to work
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
MORREALE5
Sep 13, 2015 09:16 PM
Hello, Michael
Aug 20, 2015 03:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
