In my climate Controls panel, ya know how the fan **** has increments, its not actually a free spinning ****.
well all settings work except the highest, when I turn it to that, the fan is off. Is the fan or something up there bad, or could it just be the controls?
Kj Rockz
close
- Join DateAug 1999
- LocationMililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car91 Camaro 77K
- Engine3.1 Vslick
- Liked:0 Times in 0 Posts
Well you could do a search....
But I think I can answer this one.
I had the same thing happen in my 88 Bird.
I replaced the HVAC unit, and bam...
Problem fixed.
I'm pretty sure it's just your unit.....
Problem fixed.
thanks man, see you are good for something
j/k, I just like to give ya sh**, thanks
That may not be the solution. I did that in my Sport Coupe, still the fan did not work on high.
On most GM cars there is a realy for high blower operation, i had to replace then alot on S-10 blazers when i worked for GM.
althogoh i do not remember having one in my Formula i may have to go look now.
There is a RELAY (realy??)located on or near the engine side of the blower motor assembly. The highest position on the fan is controlled by said relay. The wiring diagram in the Chilton's manual should show you the correct wire color combination for the relay.
I really wish there was a spell check on the bb.
Kj Rockz
close
- Join DateAug 1999
- Car91 Camaro 77K
- Engine3.1 Vslick
Well I replaced my relay atthe same time.
So you might want to check that too...
