sealed beam xenon conversion
Old Oct 4, 2002 | 08:37 PM
jcjohnston78's Avatar
i have done a search for "sealed beam xenon conversion " i found several different companies but i would like to get a recommendation and good place to buy.
anybody out there got them??
are you able to replace the high and low beams or is it just the low beams???
thanx
Old Oct 4, 2002 | 10:28 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
ebaymotors.com
Old Oct 4, 2002 | 11:00 PM
ive seen them on there but dont know anything about them or if there any good
Old Oct 5, 2002 | 05:45 AM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
There all about the same just make sure it comes with the wiring harness.Personally i dont like the conversion kits Because when i owned mine they would stay on for awhile then would dim i would have to turn the car lights off for a while before they would work again.So i got fed up with them and i bought a set of sylvania cool blues.Cool blues wont give you that deep bluish hue but it will give you alittle......I like them....
Old Oct 5, 2002 | 09:03 AM
yeah thats what i have in my car right now...i just not bright enough.....i guess ill might have to put some fog lights in
Old Oct 5, 2002 | 05:49 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I dont know if this will help but these lights are supposed to be briter than cool blues..
http://www.sylvania.com/auto/silverstar.htm
Old Oct 7, 2002 | 02:33 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Would a conversion kit be needed for those silver star bulbs ? Aren't the thirdgens using sealed bulb ?
Old Oct 7, 2002 | 02:39 AM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
You dont need a conversion kit there sealed beam.
http://www.sylvania.com/bin/carApp/c...amaro&x=17&y=6
Old Oct 7, 2002 | 08:22 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it appears as though they have an HID upgrade also
http://www.sylvania.com/xenarc/x46565006.htm
Old Oct 7, 2002 | 10:32 AM
92droptop's Avatar
Car: 1992 Camaro RS Convertible
Engine: 3.1
Lows only
With the sylvania kit anyway, http://www.sylvania.com/xenarc/x46565006.htm
it is an HID upgrade on the low beam, and a normal halogen for the high beam. apparently you can buy additional balasts and bulb units to make the high beams HID as well, but i remember reading somewhere that it isn't street legal for whatever reason, and is hard, if not impossible to get them to function as normal high beams (i.e. can't click them on and off, would need a seperate switch) They have a good wiring diagram that shows you exactly what happens
Old Oct 7, 2002 | 03:54 PM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
ChevyKen has them and I got the e-mail address for the place but they never wrote back. His look sweet! Do a search for it.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
