T-Top leaks....
Old Oct 11, 2002 | 02:08 AM
9OFirebirdV6's Avatar
T-Top leaks....
my T-Tops leak durning heavy rain, or if i dare try to go through a carwash, I was thinking about using some black weather stripping sealant to stop it, because i never really drive with them off anyways any recommendations?
Old Oct 11, 2002 | 08:35 AM
MdFormula350's Avatar
i stopped most of my leaks, but for some reason if my car has been sitting in the rain and when i first move a couple of drops come in between where the t-tops pin locks into the whole on the rear body.. i am thinking about using some sort of gasket material to fix that and i should be 99% leak free.. i think that water might actually be coming through where the lexan and the metal frame its in meets.
to stop major leaking, just peel back the weatherstripping alittle from the body and put a nice new bead of silcone (black) sealer, between the body and the weatherstipping and then put the t-tops back on and it wil dry on its own... i redid both sided, because both sides kinda leaked but one side did more than the other.. its been raining over my house for about 1 and a half straight i am waiting when it stops i am going water seaching in my car
but it all depends and where you are leaking, your t-tops might just need to be adjested so they lock down harder..
Old Oct 7, 2009 | 08:29 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: T-Top leaks....
any updates?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
