Door Panel Install???
Old Oct 24, 2002 | 12:05 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Does anyone know the best way to take off and put on the very top of the door panel. It's the panal that is usually black and sits on the very top of the door panel. I'm puttin on new ones and I'm having trouble with the install. Thanks for your help.
Old Oct 24, 2002 | 06:09 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Roll your window all the way down and push the panel toward the window and up should slide off. I did my door panels 2 days agop and im very happy with the results.
Old Oct 24, 2002 | 06:41 PM
CamaroMike's Avatar
I just did this! I know exactly what you are dealing with! Those stupid upside down speed nuts. I tried to put one on the same as factory with a pair of pliers and I just ended up damaging the plastic stud. I ended up fliping the nuts upside down (or normal install for the rest of the world) and managed to catch about one thread on each plastic stud. It holds firm and I have not had a problem to date. I also checked with Snap-On, Mac, and Matco and no one makes a tool to do this job. I would love to see how the factory does this installation.
Old Oct 24, 2002 | 07:20 PM
man i hear ya on those dumb things, i just used some needle nose pliers and only damaged two plastic studs...but i did use some super weatherstrip adheasive at the top so that **** aint goin nowhere
Old Oct 25, 2002 | 11:20 AM
5SIZ's Avatar
Car: 1987 IROC-Z
Lower window, push in towards the window and lift up, easy as that. But I recommend you start from the front of the door by the engine bay and work your way back, it makes removal even easier.
Old Oct 26, 2002 | 06:06 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
I'll try that, thanks for all the help!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
