front end ?
Old Nov 7, 2002 | 06:27 PM
z28man4life's Avatar
front end ?
i need to know if i need a spring compressor to change my shocks and struts on a 1991 z28 camaro with a 5.7 liter engine all advice is welcome. and also if there is anyway to get the key that holds my rims on off without the key let me know.thanx
Old Nov 7, 2002 | 07:38 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
theres a tech article on how to change springs on the main page under "technical articles' check it out it'll help a lot. but if i recall correctly you most likely will need one in order to remove them. as for removing your locking lug nuts without the key try doing a search. best thing would be to weld on a socket to the lock and then just scrwe it off, take it to a wheel shop they will be able to help you out, or finally tighten the other 4 bolts as much as you humanly can in order to take the stress off of the lock and then use a channel lock or something to try and take it off good luck
Old Nov 7, 2002 | 09:03 PM
panman79's Avatar
you will definetly need the compressors
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
