Lift off hoods
Old Nov 18, 2002 | 07:59 AM
mshapiro's Avatar
Lift off hoods
I want to get a cowl lift off hood from summit/jegs.(harwood i guess)....anyway if i got pins for it(2 front, 2 rear)...will it still want to fly off? Is it unsafe to have a lift off for street use?
Old Nov 18, 2002 | 11:29 AM
CR-SuperChevy's Avatar
if you use 4 points its perfectly safe if installed correctly think about it a normal hood only uses 3 points to attack itself?
Old Nov 18, 2002 | 12:05 PM
bob8748's Avatar
In my opinion lift off hoods are a PITA. takes two people eveytime you check oil...etc. Doesnt Harwood make a Fiberglass hood with light tension springs? That would be the way to go.
Old Nov 18, 2002 | 04:59 PM
VortecZ's Avatar
Car: Camaros
I've got the Harwood lift off hood on my Camaro. I started with 4 pins in the corners and that just wasn't enough. It still wanted to lift up in the middle at interstate speeds. I added two more front and center. The two that I added are locking pins so no one can steal my hood which is something to think about. It is light enough that I can take it off by myself which is great for working on the motor. Also, you don't have to take it all the way off to check the oil and things like that. You do, however, have to take all the clips off of the pins and pivit it up just as if it had hinges. I keep a yard stick with me to prop it up.
They do make a hood that uses the stock springs and latches. The lift off is much lighter and half the money but more of a PITA.
Here is a pic of it to show where the pins are located.
http://www.hustonstreetracing.com/friends/nate4.jpg
Old Nov 18, 2002 | 10:21 PM
bob8748's Avatar
Nice ride VortecZ
Not much into flames but yours has taste... I like the red too.
Old Nov 19, 2002 | 12:38 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
i have a hardwood lift off cowl hood, its the 4inch, and i have it sitting in my garage, and i was wondering how hard is it to mount these hoods, i got it a while back and my dads wanting em to put it on or sell it, i want to put it on, so if anyone can PM me or post, prefered pm, about where their hood pins are located and such, thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
Jorlain
Oct 8, 2015 01:57 AM
blackandblue02
Sep 10, 2015 08:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
