ebrake slips
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
ebrake slips
my ebrake slips and i dont know why. i have a stick so i just keep it in reverse when parked but i still want the ebrake to work
What do you mean by "slips"? Does it engage at all but wont hold the car? Does the handle go all the way up with little or no tension? Does the handle not stay in the locked position? Need more info please!
Mike C.
Mike C. Senior Member
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
If it goes up but doesnt feel like its holding tighten your rear brakes up, a lot of peopel used to losen the back brakes to burnout better but that affected the ebrake. The previous owner on my cousins formula 350 did that and hes gotta heve em tightened
Car: 83 Camaro
Transmission: th350
the ebrakes on our cars suck *** stock anyways....if i ever have to park on steep hills or anything i just grab something from inside my car and throw it behind the rear tire...you can neva be too careful
my car has a self adjusting e-brake.
one day it just started slipping al the way up and did not engage at all.. i sprayed some wd-40 or somthing that does the same thing on the mechanism and the lines.. and then it broke loose and started working properly again..
UltRoadWarrior9
Sep 2, 2015 08:24 PM
