Removing Dash Trim plate from '92 Camaro
Old Dec 9, 2002 | 07:00 PM
stiers's Avatar
How does the trim piece that holds the cig lighter, defrost buttons, and headlight switch come off the dash. I can get it all off except for the part around the headlight ****. So, does the **** just pull off(I pulled pretty hard and it didn't want to come) or is there something else you have to do?
Old Dec 9, 2002 | 08:08 PM
Rage13's Avatar
Car: 89 Firebird
yeah, you have to get in behind it... there is some little button you have to press that releases it, if you look in a repair manual it explains it pretty well.
Old Dec 10, 2002 | 04:17 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I can't recall exactly cuz I'm many miles away from my own car, but I believe you need to drop the lower dash panel which will expose about four 7mm screws (2 on each side of the column). Gotta remove those and then the rest of that trim just snaps in place, so you'll have to pop it off. As for the headlight switch, you gotta get behind that panel and there is a little button that will release the pull switch. OR... if you're careful... if you pull on it and wiggle it just right, it'll come out... then re-insert it just enough to turn your lights back off... you'll see what I'm talking about once you get in there...
Old Dec 14, 2002 | 11:30 PM
stiers's Avatar
OK, i am really gettin mad...I cant get this thing out, what exactly do you have to pull off to get access to the switch to release the shaft? I got the dashpad off and the speaker out but i still can't get in there...WTF?
Old Dec 14, 2002 | 11:47 PM
Rage13's Avatar
Car: 89 Firebird
its been about 7 months sence i been behind the dash but i belive once you have the dash pad off you can reach down behind the headlight switch and right below the shaft that the healight **** is on there should be a little button, hold the button and give the switch a little tug, hope that works for ya, and if not then come back with the year of your car and i'll run down to the junk yard and figure it out there for you
Old Dec 15, 2002 | 02:05 AM
stiers's Avatar
I finally figured it out. I have a '92, so I am begining th think it is a little different under the dash. There was no way to get to the button from above. I ended up taking off the fog lamp switch and sticking a long screwdriver down and pushing the button. Still didn't fix my problem(rear defrost doesnt work) but at least I made some headway.
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
3rdgenparts
Aug 8, 2015 07:09 PM
