doing polishing with dremel?
Old Dec 24, 2002 | 06:19 PM
burnouts4ever's Avatar
doing the polishing step with my rims and pipes using an attachment for the dremel using compounds would this work well? if so what attachment/ments would i need?
Old Dec 24, 2002 | 08:08 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
Sorry to tell ya, but it wont work. I recently polished my wheels, and tried the dremel route first. It dosent spin fast enough to do any good. What I did was bought a snap on die grinder, and that worked superb. It has to be a fast one, like 40,000 rpm's i think, and have the tork. The drmel has the rpm's but dosent really do it for some reason. Just to let you know.
Old Dec 24, 2002 | 08:48 PM
how much was the die grinder?
Old Dec 24, 2002 | 09:15 PM
87RS402's Avatar
Just for fun one time I tried to see how well the edges of my camaro wheels would shine up by polishing with my dremel and I got pretty good results.
You have to sand off the clearcoat and then work up to the polishing stage but once their done it's easy to maintain. Just don't push hard when your polishing so you can keep the RPM's up, push only hard enough to work the buff, not slow it down.
Old Dec 24, 2002 | 09:49 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i paid $120 for my Snap-On die-grinder
you'll need an air compressor also
Old Dec 25, 2002 | 01:17 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
I paid 150 for mine. and it worked perfectly.
Old Dec 25, 2002 | 02:55 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
http://www.harborfreight.com/cpi/cta...emnumber=53177
How about $8?
Lon
Old Dec 25, 2002 | 08:02 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
How about $8?
Lon
that is just the kit
Brian
Old Dec 25, 2002 | 08:06 PM
lonsal's Avatar
You're right. It is a kit, consisting of a die grinder, 5 stones, air nipple and wrench. They wouldn't list the "air requirement" for the tool if it were only a tool accessory kit without the die grinder.
Lon
Old Dec 25, 2002 | 10:32 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
So when using a die grinder you just use the normal grit bits you'd use if polishing by hand? like 180, 220, etc. working your way up?
Old Dec 25, 2002 | 11:41 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Lon
My bad. It is a crap kit though. 22000 rpm wont get you very far. I have a 40000 and it does the trick, I cant imagine using anything less than around 30000.
Brian
Old Dec 28, 2002 | 05:24 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
i picked up a die grinder for about 30 bucks, spins to about 30k rpm and works fine
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
