power 4th gen into pwr 3rd gen???
Old Dec 25, 2002 | 11:02 PM
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
i know the seats from a fourth gen are direct bolt ins, and i did do a search, but i found no info on how to hook up the electronics of the power seat....IE i have an 86 iroc w/ power dr. seat, how do i get the 4th gen power seat hooked up?? sorry if it has been a repeat Q, i just dont know the answer thanks to all!
Old Dec 26, 2002 | 02:57 AM
91ConvertableZ's Avatar
If you didn't already have power, you'll have to run your own power wire, and don't forget the ground wire. And if you can find a wireing diagram from a fourth gen, you'll be able to find out what wires are pos & neg.
Old Dec 26, 2002 | 02:02 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The orange wire is positive and the black one is negative.
There are only two wires to hook up the power seat.
I have had a 96 Camaro SS power drivers seat in my car as well as 96 Trans Am seats with power bolster and lumbar.
Old Dec 26, 2002 | 02:03 PM
2vmodular's Avatar
from a 00' transam:
larger versions of the above diagrams are avaliable here:
http://www.p71interceptor.com/fourth...powerseat1.gif
http://www.p71interceptor.com/fourth...powerseat2.gif
http://www.p71interceptor.com/fourth...powerseat3.gif
Old Dec 26, 2002 | 05:44 PM
gflo383's Avatar
Car: IROC Z
i wasnt sure, thanks alot fellas. it will be the simplest swap i have ever done!
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
