Pulling Light Swtich off?
Old Jan 2, 2003 | 03:03 PM
HaroGt14's Avatar
I am installing a tach in my 91 camaro. And I was wondering ... how do you get the light switch off so that I can access the cluster and begin connecting all the wires. I have everything else apart but im having a hard time pulling the light switch off. And I have a chiltons but that isn't helping me too much.
Any advise is helpful.
Sean
Old Jan 2, 2003 | 04:50 PM
DaGoat's Avatar
I am assuming that you are referring to the headlight switch ****? If you are there is a little retainer clip holding the **** to the shaft. You need to wrench your neck as far to the back of the **** as possible and you should be able to see the edge of the clip. I have found that most of these ***** have a little notch where the clip is. If you're with me so far, use a VERY small screw driver, and while applying pressure towards you on the clip, pull the **** off.
Like I said this is an assumption as to your application.
Old Jan 3, 2003 | 05:41 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Or you can pull really hard on the ****. It and the clip will come off. REALLY hard.
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
stalkier
Aug 21, 2015 01:54 AM
Omega
Aug 10, 2015 12:46 PM
