Speedo Questions > > >
Old Jan 13, 2003 | 02:40 AM
92GTA's Avatar
I'm going to swap in a 140 speedo cluster into my GTA that has the 120. When I do the swap, will there be any calibration needed or will the 140 work just fine? I ask because I have a 2.73 rear and 140's usually work with a 3.23 or simlilar gear...
Old Jan 13, 2003 | 07:55 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
im guessing you are the same 92GTA over on hoodscoop.com? i am mattp over there...
on to your question, i have a 145 speedo in my IROC and it also has 2.77 gears in the BW 9bolt. i hope this helps some. at worse, youll need to get a speedo gear from GM.
Old Jan 13, 2003 | 08:03 PM
92GTA's Avatar
Yup, that's me. I'm 92GTA everywhere.
So you did the swap and didn't have to change the gear? Cool.....
Old Jan 14, 2003 | 09:33 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
no , no swap. stock 145 speedo with 2.77 gears...
the only thing ive really done to the car is to put in a t56, nothin else. i was just giving you that example to show that 145 speedo might (should) work with 2.73 gears.
any thought to going to some steeper gears? say maybe 3.42 or 3.73?
Old Jan 15, 2003 | 01:30 AM
92GTA's Avatar
I'm already ahead of you. I'm installing a rebuilt tranny and a brand new posi with 3.42 gears in about 3 weeks. I of course know I have to change the driven gear in the tranny for the 3.42's but I just wanted to make sure I didn't have to change the speedo gear too.
Thanks!
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
