How loose is your steering wheel colum?
Old Jan 16, 2003 | 03:14 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I recently replaced my stock steering wheel with a new Grant sig series. When I first got it, I tried to take off the old steering wheel with brute force. After that didnt work I got a steering wheel puller and got it off and the new one on in a jiff. Now I have noticed that I have ALOT of wiggle in the colum. I can probably lift the wheel close to an inch and can wiggle it from side to side about an inch also. Is there something that I could have broken with my superman like strength ? Or is there something that I might have gotten too loose that I can tighten?
Any help would be appreciated.
Brian
Old Jan 16, 2003 | 03:37 PM
Jza's Avatar
Jza
Is it the whole column at the tilt joint, or just the wheel?
Be careful with those Grant adapters. They're made of a really soft metal that strips and wallows easily.
If it's not the wheel/adapter, but the column itself, then you'll have to disassemble a goot chunk of it to get to these three screws to tighten. Use a thread retention compound when you do to prevent future reoccurances.
There should be a tech article here or at a linked site that explains a good hot-to on this subject. It's pretty common in the 80s era GM cars and trucks.
Old Jan 16, 2003 | 08:44 PM
MdFormula350's Avatar
might need to just tighten the column up..
https://www.thirdgen.org/newdesign/t...ngcolumn.shtml
Old Jan 16, 2003 | 09:00 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Cool, thanks guys. Ill have to do that this weekend.
Brian
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
