What did I do wrong to get swirl marks?
Old Jan 18, 2003 | 11:21 PM
reborn92rs's Avatar
Car: 92 RS
Transmission: auto
I got a buffer for christmas so I decided to test it out on my t-tops today. The ttops are in terrible shape so I figured they couldnt get any worse. Whatever kind of coating was on them peeled off and theres that spider-web cracking throughout them as well. I sanded from 600, 800 to 1500 and then took some 3m rubbing compound to the top with the buffer. When I finished it came out much better than I expected except there are 2 swirl marks obviously made by the buffer accross the ttop.
What did I do to make those? Push to hard/light? Not have it flat on the surface??
Old Jan 19, 2003 | 01:06 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you have to learn how to move the buffer around properly....i would suggest getting a piece of steel and a grinding disc on your buffer and buff the steel
that way you can figure out how to move it around smoothly enough to not leave swirl marks....also how hard or soft depends on a lot of things
Old Jan 19, 2003 | 04:46 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
yuo probably put it on there to long and burned the **** off.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
gord327
Oct 3, 2015 01:25 PM
