weird t-top leak
Old Jan 21, 2003 | 08:44 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
weird t-top leak
my t-tops never leak untill they are hit from the side like when i am washing it or spraying the windows off it seems like my windows dont push against the seal hard enough to make a seal and when i close my door if i dont put a light push on the window it will hit my t-top trim and make a loud smack and it wont seal right i dont know if there is anything that can be adjusted to make this stop because my mom took it to the touchless car wash the other day and she was as wet as the outside of the car even though it was funny my interior was soaked i just read the vasalene trick but i dont know if that will work for my leak thanks for any help.
Old Jan 21, 2003 | 10:14 PM
MdFormula350's Avatar
well you can pull the front and rear trim pieces in the pic..
and they are bolts for each corner that you can adjust the t-tops up and down, and even a lever that go go out and in to push against the weatherstripping better.
just a thought if you havent did that yet..
Old Jan 22, 2003 | 03:29 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
I never knew that! Thanks for the heads up!:hail:
gta892000
Aug 11, 2019 11:16 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
codeysabatini
Sep 20, 2015 11:36 AM
blackandblue02
Sep 10, 2015 08:19 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
