How to adjust hood latch?
Old Jan 28, 2003 | 11:00 PM
jc92formula's Avatar
I hope someone can help me out here...
When my hood is closed, there is a 1/4-1/2" gap between the hood and bumper. It bothers me. Alot. Is there some way to lower the latch assembly? I tried doing a search and just couldn't find what I was looking for.
Thanks!
Jon
Old Jan 29, 2003 | 07:06 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
There are 2 bolts you can loosen to move the latch up or down. There's also the rubber bumpers you can adjust too.
Old Jan 29, 2003 | 07:57 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Firebird's have 4 adjustment ***** under the hood, 2 next to the lights and 2 at the hood corners, but of course none of the pictures of my engine bay that are online show the *****.
What I did was adjust all the ***** all the way down, to make sure there wasn't something else holding up the hood. IF it is your latch that is holding the hood up, there are a couple bolts holding the lower latching assembly that can be loosened and would allow for some adjustment. It is highly unlikely that this is holding your hood. Once verified, raise the ***** to raise the hood. Once it's set they shouldn't move. If they do, try some locktite.
GL!
Old Jan 29, 2003 | 02:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Usually when the latch is misadjusted, you'll have a problem opening or closing the hood. Either the hood won't "pop open" when you pull the cable, and you gotta wiggle the hood to open it, or, the hood pops open too easily. I'd definately hunt down all those rubber bumpers, first.
Old Jan 30, 2003 | 12:19 PM
MdFormula350's Avatar
yeah the two front bolts you can loosen and then move down the latch abit, i just had to do that a few weeks ago..
Old Jan 30, 2003 | 11:11 PM
*Update
Well it took me all of about two minutes to adjust the latch down a little. Thanks. I'm serious, it was really hard for me to look at the front of my car w/o that jumping out at me!
Jon
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
greenyone
Sep 8, 2015 08:41 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
