Car stored outside growing mold!
Car: 1984 Camaro Z28 HO
Engine: L69
I've had my 84 Z28 stored outside over the Winter and it's had a little problem with moisture. It has a bit of a leaky T-roof and hatch, but not enough to get the carpet really wet, just a little damp after a rain.
Apparently this has been enough moisture to start a science-fair project growing on the the leather in my car. The shift **** and steering wheel have a nice green fuzz growing over it. I've cleaned it off, but it seems to come back after a week or two. The bigger problem is I don't know where else this mold is starting to grow. I definitely don't want to be discovering any fun surprises in the future.
So what can I do to control this moisture problem (assuming that it is what's causing the mold.) Anyone else had this happen before? Any tips on storing a car outside in a rainy place? Thanks!
Car: 83Z28 HO
Transmission: G Force 5 speed
WoW!!! Sounds like maybe a moisture problem to me...most likely from your carpet. I bet it stays moist for quite awhile after a good storm, and doesn't get "aired" out.
Just my guess. You didn't mention whether you have a cover on it or not - but if you don't, get one.
But before you do- I'd put it in a garage if possible and keep the windows down for a few days to dry out.
Car: 83Z28 HO
BTW....get the T-top and hatch leak fixed...that's where this started anyway...
j/k
j/k Member
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
My parent's use a little thing called a Dry-Z-Air in their Trailer when it's stored for the winter.... sort of a dehumidifier
check it out:
http://shop.store.yahoo.com/safetyfi...zmoisrems.html
It's cheap too!! I'm going to pick one up for my car when it comes off the road in a couple days
check it out:
Engine: L69
Thanks for the replies guys. I started out putting a box of baking soda in the car since I had some handy. While it definitely reduced the "respawning" rate of the mold, it's still coming back slowly. So I went out and bought some "Dry-Z-Air" as recommended. Hopefully it will do the trick since it's a little more intended for this sort of thing. I'll let ya know.
I actually neglected to put a car cover on it, not sure why. Definitely something I will do for next year. Unfortunately I can't stick her in the garage because my other Camaro is being stored there. I'd rather have the 84 engulfed in a ball of mold then have my real "baby" outside.
1992 Trans Am
May 10, 2023 07:19 PM
Linson
Aug 21, 2015 02:12 PM
