Door lock clips
Old Feb 3, 2003 | 11:57 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Door lock clips
i had to put new door locks on my 85 z today and i noticed the little clips that hold the rod to the lock cylinder are missing. is there anything i can i do to get that rod to stay on, or if i have to get new clips can i get them anywhere?
thanks
Old Feb 4, 2003 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
In the long run the clips are the best bet. I would think that they're still available from GM--if not try the boneyards. While you're in the door, you might consider cleaning and lubing (with white grease), both the door lock mechanisms and window tracks. If you have rattling/noise problmes, check the following:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old Feb 4, 2003 | 08:16 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Regular E-clips should work too. Those are available anywhere.
my86bird
Oct 23, 2015 12:20 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
NiG
Sep 7, 2015 11:25 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
