Window/Door Rattles--Observation and Pics
Old Aug 6, 2002 | 01:04 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
First consider rubber in general. All weather stripping should not only be in good condition but also be pliable (use a shot of silicone on them from time to time). Aside from the rubber surrounding the windows, there are the window bump stops, which wear quickly and fall to the bottom of the door.
Attached Thumbnails Window/Door Rattles--Observation and Pics-bumper1.jpg
Old Aug 6, 2002 | 01:06 PM
JamesC's Avatar
Then, there is a piece that is still available from GM, but isn't installed on all cars, a piece that seems to make the door a bit more airtight and solid.
Attached Thumbnails Window/Door Rattles--Observation and Pics-rubber1.jpg
Old Aug 6, 2002 | 01:07 PM
JamesC's Avatar
Here's the latter installed.
Attached Thumbnails Window/Door Rattles--Observation and Pics-rubber2.jpg
Old Aug 6, 2002 | 01:10 PM
JamesC's Avatar
The door handle itself is another problem. The small spring inside the handle often breaks/weakens and allows the handle to flop. On the 88 Camaro that I inspected, the self-cutting nuts of the handle itself had also loosened to allow flop.
Attached Thumbnails Window/Door Rattles--Observation and Pics-handle2.jpg
Old Aug 6, 2002 | 01:13 PM
JamesC's Avatar
Moreover, the handle design fits metal 'fingers' into metal rectanglar 'boxes', which is, of course, metal on metal. I'd advise shooting some white gease in occasionally to slow wear, which will cause flop.
Attached Thumbnails Window/Door Rattles--Observation and Pics-handle3.jpg
Old Aug 6, 2002 | 01:15 PM
JamesC's Avatar
Inside the door. The window guides may cause some difficulties, but my guess is that the real problems lie elsewhere.
Attached Thumbnails Window/Door Rattles--Observation and Pics-guide.jpg
Old Aug 6, 2002 | 01:19 PM
JamesC's Avatar
In my 85 IROC, the cause of most of the rattling came from the various rods that open, close, and lock the door. Apparently, GM made two versions of gizmos to hold and cushion those rods.
Note the two rods. On my 85 the black piece only holds a single rod in place, allowing the second to flop, although the mesh does help.
Attached Thumbnails Window/Door Rattles--Observation and Pics-851.jpg
Old Aug 6, 2002 | 01:21 PM
JamesC's Avatar
My fix. I put in the second style holder (from an 88), which secures both rods and then spliced on some vac hose.
Attached Thumbnails Window/Door Rattles--Observation and Pics-852.jpg
Old Aug 6, 2002 | 01:22 PM
JamesC's Avatar
Here's what the second design from the 88 looked like stock. Note the foam piece. It's deterorated enough already to allow some flop.
Attached Thumbnails Window/Door Rattles--Observation and Pics-88.jpg
Old Aug 6, 2002 | 01:24 PM
JamesC's Avatar
Other rods cause problems as well. Some of these rods are covered with a plastic-like black material. Nonetheless, wear is caused, elongating holes and further causing rattles. A prime culpit is just above my finger. As a short-term fix, I simply looped a small zip tie through the hole (barely visible) and around the rod and snugged it up.
Attached Thumbnails Window/Door Rattles--Observation and Pics-manual1.jpg
Old Aug 6, 2002 | 01:26 PM
JamesC's Avatar
One more rod. I fixed it as above.
Attached Thumbnails Window/Door Rattles--Observation and Pics-manual2.jpg
Old Aug 6, 2002 | 02:44 PM
MdFormula350's Avatar
very nice work man!!
thanks for all the pics and information, you rock :hail:
Old Aug 6, 2002 | 04:50 PM
CrazyHawaiian's Avatar
Car: too many ...
I smell a tech article!!
Old Aug 8, 2002 | 04:58 PM
JamesC's Avatar
More possible problems and fixes. On my 85, there was no vestige of rubber on the door latch itself, although there clearly was on the 88 as you see below.
JamesC
Attached Thumbnails Window/Door Rattles--Observation and Pics-latch1.jpg
Old Aug 8, 2002 | 05:00 PM
JamesC's Avatar
Note the wear on the striker. Again metal on metal.
JamesC
Attached Thumbnails Window/Door Rattles--Observation and Pics-striker.jpg
Old Aug 8, 2002 | 05:03 PM
JamesC's Avatar
I tried several fixes, wrapping the striker with various kinds of rubber and so on, none of which worked. What I settled on, since the striker is exactly the same size, is the striker cover from the rear seat.
JamesC
Attached Thumbnails Window/Door Rattles--Observation and Pics-plastic.jpg
Old Aug 8, 2002 | 05:06 PM
JamesC's Avatar
I cut it to size with a dremel, removed the door striker, pushed on the plastic, and reassembled. So far, the plastic shows no signs of heavy wear.
JamesC
Attached Thumbnails Window/Door Rattles--Observation and Pics-fix.jpg
Old Aug 8, 2002 | 05:56 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
damn... that just about answers any questions I had about this.
Old Aug 8, 2002 | 11:25 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Another suggestion. You can just buy a new striker from GM. I picked up several to swap whan I start performing the 3rdgensolutions hinge replacement on local Members cars. The p/n for the door striker bolt is 20464563. Lon
Old Oct 19, 2002 | 12:02 PM
2vmodular's Avatar
http://www.p71interceptor.com/thirdgen/powerlocks
here's pictures of the drivers door with part of the outer shell cutaway:
Old Oct 19, 2002 | 03:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The poor mans way to seal up the doors and windows.
1/2in wide 1/4in thick weather striping they sell for doors and windows for your house. 2-3 bucks for a big roll.
works real well. I used it all around my windows and doors, so they seal tight and they no longer get frozen shut in the winter. It also works well on the hood and hatch seal.
I broke off my passanger side door handle and broke my hatch lock one winter, got frozen out and could not get in.
Old Oct 19, 2002 | 03:27 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
I tried ajusting those guides since my window wobbled
alot. but by pushing the guide(s) forward.. now i get
wind noise at 60 km/h. Thats annoying !
on the end of the guide theres some sort of a brush that
pushes against the window wich is worn out..
Old Oct 19, 2002 | 04:23 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Please a detailed if possible tech article. Very well done.
Old Oct 20, 2002 | 07:19 AM
SLOW5.0's Avatar
Where to find the rubber bumb stops? that is what is holding me back from installing my door panel
Old Jan 11, 2003 | 09:48 AM
dsaint1347's Avatar
Where can I find this?
Old Jan 11, 2003 | 10:06 AM
JamesC's Avatar
Both the window bump stops and the door piece should still be available from GM. I have an extra door piece, should it be unavailable from the General.
JamesC
Old Jan 11, 2003 | 02:31 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Is there any kind of P/n on the weatherstripping? I would like to get one for my car.
Old Jan 12, 2003 | 07:58 AM
JamesC's Avatar
I can't locate the part number(s) from old bills, but the parts man at your local dealership should be able to provide it. There are, I believe, after market options as well, such as Soft Seal (you might save a few bucks there). By the way, you might consider not only replacing the rubber around the windows but also around the doors.
JamesC
Old Jan 13, 2003 | 01:13 PM
PrimerGrey's Avatar
Sure wish I'd found this site sooner. I did all the weatherstripping in my 88 Sport Coupe this weekend. Great info here. BTW SoftSeal offers a complete weatherstripping kit for 3rd gens. It's 250.00 something for all the seals and they fit perfectly.
Old Feb 4, 2003 | 08:05 AM
JamesC's Avatar
I've offered this link to several people recently, so I thought perhaps I'd bump it to the top.
JamesC
Old Apr 13, 2003 | 11:03 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Again, very nice job!
Old Apr 13, 2003 | 07:04 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I found your post very helpful!!
I just went out and checked all the areas you talked about. I picked up some foam at the fabric shop, and wrapped it around where the rods hit the metal of the door. Silence is golden! I'll try to get a few pics.
Old Apr 14, 2003 | 08:17 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Very nice work!
One more place where I found a squeak is that metal wedge thing that's on the body side of the door jamb. It contacts a corresponding hard plastic wedge attached to the door. A very small smear of grease on the two parts eliminates this squeak.
Old Apr 14, 2003 | 03:25 PM
87IROC350HO's Avatar
Yea Thanks
Old Apr 15, 2003 | 11:10 AM
JamesC's Avatar
Paulo,
The pieces you mention are not equipped on the earlier cars--at least my 85 IROC doesn't have them. The 88 that I discuss above, however, did. Apparently, the General came to understand that the doors and rattles were a problem and made some minor improvements in that regard.
JamesC
Old Apr 15, 2003 | 12:23 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think 87 was a big year for a lot of those improvements, to help reduce rattles. I know mine had most of those from the factory EXCEPT the Lower Door rubber piece that he describes (Got one from another car, makes the door close harder but it helped with some squeaks. I think my 91 had it tho...
John
Old Apr 15, 2003 | 03:43 PM
Mathius's Avatar
What book are you referencing here? The diagrams are far superior to anything found in the Chilton's, or Haynes manuals.
Mathius
Old Apr 15, 2003 | 06:42 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
JamesC
Where do you get the plastic peices to fit over the door strikers? How hard is it to put them in??
Old Apr 15, 2003 | 07:20 PM
FastElectrics's Avatar
Car: 89 Camaro RS
The book he is showing is the GM Shop Manual.. Check Ebay from time to time.. I see many thirdgen manuals there.. I have a photo copy of the whole book.. no color.. but it's great to have.
Old Apr 15, 2003 | 08:12 PM
JamesC's Avatar
FastE is correct, shop manual (If you don't have one, get one asap). Torch, see above for pics and instructions--I think your question can be answered there. If not, let me know.
JamesC
Old Apr 15, 2003 | 08:35 PM
TorchRay's Avatar
Car: 89 WS6 Formula
yeah i see your post there discribing it. Thanks. What if i was just looking for the plastic circular pieces to go over the door strikers? Can i find them at like an auto parts store? I checked my dads new van and hes got them on all his doors. Just thin circular peices of plastic that go over the strikers.
Old Apr 15, 2003 | 08:46 PM
_max_'s Avatar
awesome work JamesC
thank you for taking your time to share this with us :hail:
Old Apr 16, 2003 | 06:35 AM
JamesC's Avatar
Torch,
I simply used the plastic from the rear seat striker (hit the bone yards--these would cost next to nothing), removed the door striker, then cut the plastic to fit (length). Reassemble.
JamesC
Old Apr 16, 2003 | 06:12 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
You are the man!!!!:hail: :hail: :hail:
Thanks for all the tips on fixing rattles/squeaks!!!!!
Now, all I need is some rear seat striker covers, new weatherstripping, and rubber bump stops....
Already got the double holder things, mesh, and foam out of an '87 parts car...
Thanks again James!!!
Old Apr 29, 2003 | 11:39 PM
Odyssey's Avatar
BTT
Old Apr 30, 2003 | 02:24 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Awesome! Thanks for taking the time out to write this down! You da man!
Felix
Old Apr 30, 2003 | 08:59 AM
redraif's Avatar
Transmission: Th700R4
Cool idea for the stricker covers. i noticed my door latch that locks on the door stricker is actually covered in plastic, so i ahve no real striker wear or vibration. That might only be cause my doors have not sagged yet. I bet the common sagging destroys the door latches plastic cover quick!
Very good stuff here...thanks for the info and tips! Gives me an even bigger list for the yards!
Old Apr 30, 2003 | 09:16 AM
Odyssey's Avatar
I tried some of the tips on the door and it worked. The driver's side door is a lot quieter now. BUT the door striker cover idea did not work The door wouldn't close after putting that cover on. I guess it was too thinck and it wouldnt latch around it or something. So I had to take it off :/...
Old May 1, 2003 | 11:06 AM
JamesC's Avatar
Odyssey,
Could very well be as redraif suggests: the door has dropped. With the door open, try to lift the door at the rear. You may note some play. If so, you might consider investing in one of Lon's fit-it kits.
JamesC
Old May 20, 2003 | 07:17 PM
Mylilbowtie's Avatar
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
I have a cheap way to make plenty of those plastic pieces. Just goto home depot or ace hardware or lows and get some pvc line in the diameter that you need and cut to length and have plenty left if you need more or mess up.
