Door panels soaked???
Old Feb 20, 2003 | 09:25 AM
92camaro44's Avatar
My door panels get extremelly wet when it rains...im almost 99 percent sure it is my door weatherstripping..is it?..also, which part of the weatherstripping would i need..i was at thirdgenresourse//and they have a bunch of different types...i don't know which one i will need...thanks
Old Feb 20, 2003 | 02:53 PM
Marc 85Z28's Avatar
Where are they wet? Just at the bottom or from the front only? If they are wet ONLY at the bottom, check your door drains for debris. Water can get in the door and collect, eventually seeping past the plastic weather panel (if still intact). Or more likely, water is entering from the window triangles. I know there is another name for them but who cares. Anyway, they are the small triangular shaped weatherstrips behind the mirror, at the very front of the window. Either they are distorted, out of position, or even the roof rail weatherstrip could be distorted.
Old Feb 20, 2003 | 09:56 PM
92camaro44's Avatar
ill check it out..thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
