Ever seen an 82 tilt column with no turn signals on column
Old Feb 18, 2003 | 07:03 PM
bobr19's Avatar
Have an 82 Sport coupe-4 speed car-has no turn signal switch-upper sleeve where it should be is solid--has tilt down lower but shows no sign of ever having turn signals on column-- no button depress for key removal and absolutely no hole where one has been?????
Old Feb 18, 2003 | 07:54 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Thats a column from a Berlinetta Camaro. They had the turn signal lever mounted on the dash, to the left of the steering wheel.
Old Feb 18, 2003 | 08:18 PM
GTA400SBC's Avatar
Does anyone have a pic of that colum i would like to check that out.
Tommy
Old Feb 20, 2003 | 11:55 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You can "kind of" see the column in this picture of my 84 Berlinetta.
The lever that is there is for the Tilt Feature. You can also see the blinker switch mounted on the dash.....
Attached Thumbnails Ever seen an 82 tilt column with no turn signals on column-blackdeluxedrivertopa.jpg
Prodigious
Nov 7, 2020 09:23 AM
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
