4th gen console into a 3rd gen
Old Mar 5, 2003 | 10:57 PM
Firehawk505's Avatar
ok i know its already been asked but....i have a 91 formula automatic and i'm thinking of putting the 4th gen console in...but which ones will fit...i know 93-97 is diff from 98-2002 and i've i'm not sure but i think i remember hearing that u can only swap a 4th gen maunal trans console into a 3rg gen...is this true or can u use the 4th gen auto consoles to....also i have the power mirror option in my 3rd gen do 4th gens have this in the center console and will 4th power window switches work with my 3rd gen wiring...help me out guys thatnks.
Old Mar 6, 2003 | 05:54 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Welcome to the boards! Try a search if you can not get a "good" answer. Sorry i don't know too well. I am familliar with the camaro swaps, but not swaps with consoles going into a firebird. I am almost positive your center console is different from camaros. There is a thread that shows both types of 4th gen consoles. good luck
Old Mar 6, 2003 | 06:53 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Welcome to the boards!!
Yes, a 4th gen center console will bolt right into a 3rd. gen Firebird. You want a 97+ console as there are more cup holders. If you have power mirrors and windows you have to fabricate something to hold those switches. Because the 4th gen auto console has the shifter about 4" to the rear of where the 3rd gen shifter is, you want a manual trans. console. Pictures of mine installed are on the web site in my signature
A search would have negated the need to start this thread, but because your new we'll let it slide
Again welcome to the boards! Good Luck! (GL!)
Old Mar 6, 2003 | 10:00 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
But he said he already knew it had been asked....
Aparently he knows about the search button.......
Old Mar 6, 2003 | 11:08 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Can you tell me exactly what you did with your power window/mirror switches?
Old Mar 6, 2003 | 11:09 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
in his defense, i don't find the search to be all that helpful. every once in a while, i have a basic question, which i know has to have been asked millions of times, but my searches are unsuccessful.
Old Mar 6, 2003 | 11:50 AM
cg91ta's Avatar
I took 1/8" plexiglass and gradually worked into shape to fit where the ashtray was in the console. Once it fit snug I found dead center and cut the hole for the power mirror switch. Once that was done I cut the holes for the window switches. It's a tight fit for all three but can be done. I used a Dremel and cutoff wheels (2 mounted together) to do the cutting. Once done and after I tweaked everything for fit, I spray painted the bottom of the plexi and let it dry. I then went and got a product from Ace hardware called "Plastic Weld" and placed the plexi in place of the ashtray lid in the console. I used a couple clamps and glued it in. Some of the paint came off in the glue process, but you can hardly tell.
I had 3 peices of plexi that broke on me, or that I over shaped before I got it right. Go slow and easy!
GL!
Casey Meyers
Mar 2, 2016 10:46 AM
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
