Front spoiler help please!!
Old Mar 14, 2003 | 08:15 AM
mettalicirocz's Avatar
Car: 1986 camaro, 1993 nissan altima(winter beater, 1992 mustang (summer daily driver)
Engine: 350tpi
Transmission: 700r4 with shift kit
Ok guys my front spoiler is all scapped up so I figured I would take it off and get it repainted. When I took it off last night everything went smooth except for on each side there is a flat peice of medal with three studs in it that hooks to the spoiler, I snapped off all three studs on each side, does anyone know where I can get some new ones and or how to fix it??
Old Mar 14, 2003 | 06:38 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Not too sure if there are new ones still made, but you could go to a junk yard and snag a few, or you could get two strips of aluminum, thin steel and drill 3 holes in it and make it contour to the bottom of the fender. Now get 3 bolts and put them on the strip of metal and reattach it to the spoiler. That should work too since there is some room for the head of a bolt to fit behind the spoiler.
Old Mar 15, 2003 | 07:39 PM
Engine: 350tpi
could i just tap out the stock piece and use it that way??
Old Mar 15, 2003 | 08:16 PM
Car: 85 Camaro SC
Engine: V6
Yeah, you could cut the old studs out and drill a hole in its place and put a bolt thru it.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
LittleFranks
Sep 17, 2015 12:22 PM
AkDrifted
Aug 17, 2015 07:45 PM
