hood scoop
Old Mar 14, 2003 | 11:44 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
hood scoop
I'm going to put the L88 hood scoop onto the steel hood of my car. JCWhitney has it in ABS Plastic, up22.com has it in fiberglass. which one should I get, the glass one?
Old Mar 15, 2003 | 11:23 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
the glass one would be better, more rigid. althogh getting it to look ok would be tough. you are better off just getting an l88 hood for your car.
good luck
Old Mar 17, 2003 | 12:01 AM
Diabolical's Avatar
Engine: 305HO L69
i don't have $500 to blow on a hood, otherwise i would just buy the ss hood from ascd. this car has a tight budget, so external mods will be home made.
Old Mar 17, 2003 | 03:19 PM
68Beater's Avatar
Are you going to mold that scoop on with fiberglass or are you just going to bolt it on? Let me know how it turns out because i have been thinking about doing the same thing...
Old Mar 17, 2003 | 04:38 PM
Diabolical's Avatar
Engine: 305HO L69
I'm going to cut the hole out, then glass it to the underside of the hood, and use a little filler to hide the seam op top of the hood. as long as i can cut the hole nice and centered, i don't think it will be all that hard.
Old Mar 17, 2003 | 04:39 PM
Diabolical's Avatar
Engine: 305HO L69
btw, anyone have any suggestions on what tool will cut the easiest and smoothest?
Old Mar 17, 2003 | 05:17 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I don't think I would cut a hole the size of the scoop you might weaken the hood too much.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
