sagging doors
Old Mar 15, 2003 | 09:11 AM
demonchild's Avatar
sagging doors
i need to fix the doors before i get the car painted. does anyone know how to fix the sagging door problem?
Old Mar 15, 2003 | 01:16 PM
badredbrd89's Avatar
Yes-depending upon your situation, the most probable cause of the sagging is the bushings going bad and basically disinigrating. There was a detailed article on High Performance Pontiac a while ago showing how to fix this problem-check their website at highperformancepontiac .com and see if they have an archive-if not, I'll email you the pages. You basically need two hinge pins for the lower, four hinge pins for the upper, and 6 new bushings. Then you take off the hinges, and the doors, and replace the parts. Then re-align everything with things like the body mouldings as guides. Your dealer should sell all of these or be able to get them. You can also get them at top-downsolutions.com---Chris
Old Mar 15, 2003 | 03:32 PM
demonchild's Avatar
ok can i do it cheap? top down solutions wants like 5 bucks for the pins then like 100 bucks for the bushings.
Old Mar 15, 2003 | 03:36 PM
demonchild's Avatar
ive seen the web site of the person who makes the hinge repair kits. where does top down solutions get the repair kits from. i remeber there is a deal on the web site of the guy that makes the bushings for buy one pair get one free.
Old Mar 23, 2003 | 01:02 PM
I'm not real sure, my friend-I was under the impression, and still am since getting the parts for under $20 from my local dealer, that this is a job you can do in about a day. As for a "deal" or "special" I haven't the faintest idea. As I said, I got the parts-including bushings, hinge pins and detent rollers, (because mine needs to be replaced), for around $20. You can email me directly at jimi_76@hotmail.com if you have further questions.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
kkirch15
Sep 30, 2015 04:44 PM
