SLicks 2 Big :o(
Old Apr 6, 2003 | 06:54 PM
JesasaurusRex's Avatar
SLicks 2 Big :o(
K well I got a set of 15x8 Drag Lites with 4.5" back spacing and some 27x10x15 Hoosier Slicks. Tried to throw them on here today for the first time since i got the right lug nuts...theyre too big and they rub up against the side wall. 10 bolt with drums i want to know if I can cut some away no problem and get them to fit or if they are just way 2 big. If theyre 2 big what size is the biggest on a 3rd gen with a 10 bolt and drum rear. So mad right now thx a ton guys
Attached Thumbnails SLicks 2 Big :o(-mvc-022s.jpg
Old Apr 6, 2003 | 08:10 PM
BTS88IROC's Avatar
Somebody yesterday just posted pics of a white iroc with 10.5 inch slicks on it. He had to pound in the inner wheel well with a sledge.
Old Apr 6, 2003 | 11:52 PM
k will do
Old Apr 7, 2003 | 09:51 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
If you use spacers to get the wheel out a bit you should be able to get them to fit in there. I've got 9" wide on mine with standard backspacing ad theres about 1/2" clearance.
Hope that helps!
Old Apr 7, 2003 | 11:43 PM
Ya I hit in the wheel well today and now its rubbing against the top part and almost touching the lower control arms, its almost all the way on tho so imma look for some 1" spacers. Thanks guys.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
