what makes power door locks stop?
Old Apr 11, 2003 | 11:03 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
my power door locks havent worked since i bought my cark, can somebody tell me what makes them stop working? when you push the button you can hear it trying to do something but it doesnt lock so im wondering what this is and how i can fix it? it makes a kinda quiet clicking noise when you hit the lock button.
Old Apr 12, 2003 | 04:42 AM
0103837's Avatar
Car: Camaro
Engine: Gas
Transmission: Automatic
I havent had any problems on mine so I dont know exactly what the layout in thirdgens is, but I used to have a Cadillac with power locks that didnt work. On the other door the reason was bad seals, water had dripped on the solenoid. And on the other, it was just jammed. When I lubricated the lock and things and changed the solenoid on the other door (and the door seals), I never had any problems again.
Old Apr 12, 2003 | 06:20 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just try putting some lube on the slides. WD-40 or Silicone oil.
Old Apr 12, 2003 | 07:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds like a common thirdgen problem, including my 85 IROC. I simply cleaned with WD-40, then liberally shot white grease on the tracks (do the windows while you're at it). Should you have door/window rattles, this would be a good time to address them. Check the following for pics and observations about various fixes:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old Apr 15, 2003 | 05:06 PM
txhotRS's Avatar
locks
I just addressed some guy with a clunking problem ... Try the same thing I told him except.. while you're at it .. WD-40 THE HELL Out of the motor.. The message is in this same tech board ... near the top .. it's titled DOOR LOCKS GO CLUNK...
GOOD LUCK
Old Apr 15, 2003 | 05:18 PM
bad_ta_05's Avatar
Car: 85 trans am
ill try that, i also just changed both locks so that might help. is it possible to oil the motor and stuff withough taking off the door panels? iv done it soo many times its becoming a pain
Old Apr 15, 2003 | 06:24 PM
txhotRS's Avatar
I'm sure you could WD-40 the lock.. and motor.. if you just pop off the bottom corner of the door panel you should be able to reach it with the WD-40 hose... I don't know about tightening the bolts without removing it though.. also.. I don't know if you already tried .. but chech the connector rod between the actual lock and the lock motor... maybe they ARE unlocking and just not connected to the latch..
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
