Removing Door panel
Old Apr 14, 2003 | 06:04 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Removing Door panel
I am having trouble removing the door panel. I read the tech article about window motor replacement and I have done some searches and I still have trouble. I can get the thing loose no problem, but I cannot get to upper plastic piece free. I cannot move my window down, won't move anymore at all. I want to replace the window motor, but cannot get that stupid door panel off. Somebody please help me. I am afraid I am going to break the thing if I bend it too far in the wrong direction. Thanks in advance.
Old Apr 14, 2003 | 10:05 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
as far as i know, the only way to get it off without the window down is breaking it, they dont cost much and i can get u one for each side if u do break them, just let me know
Old Apr 15, 2003 | 10:04 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Are you serious? I gotta break the damn thing...that sux ***. Oh well, they are kinda loose anyway, maybe new ones will be tighter. Thanks for the reply.
Old Apr 15, 2003 | 01:05 PM
joshp14's Avatar
I'm not sure if they can be removed or not with the window up or not. I would try to get the window down first...try to force it down, you wont be hurting anything anyway cuz you are replacing the motor.
To get it off when the window is down, you simply push away (from the inside) and pull up at the same time. But I guess if you are forced to break it then you have no choice.
-Josh
Old Apr 15, 2003 | 05:03 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
All I can say is just try pushing in on the trim piece as far as you can towards the window glass, and then pull up...
I have never tried it with the window up, but it should work almost the same....
Old Apr 15, 2003 | 08:27 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I did try to do that. I tried many things to get that sucker off and nothing seemed to be working. I think my only choices are to force the window down, or to break the old upper panel piece. Thanks for the reply.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
