water leak
Old Apr 16, 2003 | 12:57 PM
Alec Klose's Avatar
water leak
I have a 1983 Camaro Z-28. The drivers floor is wet, so I know I have a water leak somewhere. Up until recently it was just the the drivers floor, but now even the floor behind the driver is wet. I just put new carpet in the car a year and a half ago and I don't want to ruin it, plus I'm afraid the floor will start to rust.
I know someone with a 91 or 92 Camaro and he said his drivers flor in wet too. The windshield in my car is still the original I think. Could the seal around the windshield be leaking? Or could there be a seem in the cowl or on the firewall that may be leaking?
Any help would be appreciated, thanks!
Old Apr 16, 2003 | 12:58 PM
Dirty Rob's Avatar
Do you have T-Tops?
Old Apr 16, 2003 | 01:03 PM
Alec Klose's Avatar
I guess I forgot to mention that. No, I don't heve T-tops.
Old Apr 19, 2003 | 03:44 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
maybe not much help, but i'll share my experience... right after i changed my heater core, i was doing a confidence check sometime later on, and low and behold, there was a wet spot - only no anti-freeze associated with it. i at least determined that it happened when it rained, or if i washed the car. when i finally got to really checking out where it was coming from, i pulled the carpet back and climbed in to the seat while i had my wife douche down the windshield area and soon enough, it started trickling in. it was coming from the joint where the firewall, kickpanel, and floorboard panels met - if you're looking at it (passenger side), it's like the very upper right corner of the dash. basically, the sealant just started rotting and leaking. i got a good temp fix on it, but gotta go back and fix it a little better. that sealant just kinda dry rots, i guess, and starts cracking... might want to check all that... hopefully that'll help some, or give you some ideas. good luck with it...
KAM
Old Apr 19, 2003 | 06:12 PM
rodrigo diaz's Avatar
Car: 92 rs
Engine: 5.0
Transmission: 5 speeds
i had water coming thru the hood release cable hole .... a little silicon and no more leak my two cents worth good luck
Old Apr 19, 2003 | 08:58 PM
Briansz28's Avatar
I just bought an 84 Z28 aand I also had water in the rear seats and floor. I found a small hole in the rear wheel well. I stuck my finger thru and I could feel the material of the seat!! I think my rear hatch is leaking too because there was a puddle in the rear well. I haven't had time to soak the areas and see where exactly. I do have t-tops and they may be leaking.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tommy z-28
Oct 6, 2015 10:58 PM
st.evel07
Sep 19, 2015 09:24 PM
84redta
Sep 19, 2015 09:58 AM
