motor for the hatch
Subscribe
Apr 21, 2003 | 07:42 PM
is it possible to put the power switch and motor which opens and closes the hatch in a car that never came with one thanks
Reply 0
Apr 21, 2003 | 08:01 PM
car did not come with one?? wow never heard that? are you sure that someone didnt weld it togeather..that what they did to mine and i hade to replace the whole thing...
Reply 0
Apr 21, 2003 | 08:11 PM
hatch
the camaro is a 1985 sport coupe with no power options so my guess was that maybe it was part of a power option or something but there are no wires or evidence of a motor ever being there, also when i bought the car there wasn't even a back manual lock
Reply 0
Apr 21, 2003 | 08:32 PM
You can put a manual latch on with a power release silenoid. My 85 SC had no power anything until I found one in the j/y. Its a simple swap, you can use your current manual release too. You just need to get the wiring harness"a long black wire, and a connector that plugs into the unused connector under the center console, and a release switch for the console" The whole thing is a direct bolt in, you shouldn't have to modify anything. I'll attach a pic of what it looks like.
Reply 0
Apr 21, 2003 | 09:12 PM
Installing a solenoid hatch releease is a piece of cake. You'd need the one specific to the 1982-85 non-motorized hatch latching unit (a picture of which has already been posted). It would be a much harder job to try and install a motorized pull-down unit, which was standard from 1986-91. Your slam-hatch latch has a completly different attachment that is spot-welded to the body that the latch bolts to than the 1986-91 motorized units used. You COULD cut that out of your car and weld in one from a 1986-91 doner car.
Lon Salgren
Top-Down Solutions
Reply 0
Apr 22, 2003 | 02:14 PM
hey thanks a lot, but does anyone have photo of where the connector is and how to run it from the solenoid lock area to the center console . thanks
Reply 0
Subscribe
