4 th gen seats
Old May 15, 2003 | 07:23 PM
92 RS JD's Avatar
4 th gen seats
i put 95 seats in my 92 how do you take the seat belt off to run a seat belt guide through
Old May 15, 2003 | 07:30 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
That may be too much work.
Someone correct me if i am wrong, but your best bet is to
A- Use a saw, and make a clean cut to slide the belts in
B- Get the same piece of from Firedbird 'Vert, and screw it on.
Old May 15, 2003 | 10:51 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
just screw the 92 guides into the 95 seats
Old May 15, 2003 | 11:37 PM
3rdGenSuperman's Avatar
Car: 1983 Camaro Z28
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
i just did this switch, i found it very easy to just use a sawzall and cut a slit. its not very noticable.i personally think it looks better with the new ones on
but the old ones should screw in just fine
Old May 16, 2003 | 07:36 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I made the cut on the mounting base. Forget about taking the seat belt off it a PITA.
Old May 16, 2003 | 01:56 PM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
It looks like you already got the answer, but yeah...dont take the belts off. Either cut the existing guide or go buy new ones for a 'vert. They're cheap enough.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
Randomtask2
Aug 21, 2015 10:54 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
