fender swap question
Old May 16, 2003 | 01:02 AM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Both my fenders are rusty and dented and Im going to the salvage yard tommorrow to find replacements.
I own an 83 Trans Am.
What year fenders are compatible with my car?
Old May 16, 2003 | 09:38 AM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Transmission: broken
I am not sure about firebirds, but with camaros any thirdgen camaro fender will work. It should be the same with the firebird. The fenders never changed they only changed the gfx and the front clips. Good luck on finding what you need!
Old May 16, 2003 | 10:48 AM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I think any TA fender from '82- '90 will work. GTA's fender should bolt on, BUT there is no fender extractor(air vent). The GTA's used the same fender as Formulas.
Matt
Old May 16, 2003 | 03:37 PM
eddie jr's Avatar
I can say this, mine is an 85 and I have two new fenders, one from an 88 and one from a 91. Even the non TA's have the body line to accept gfx (just no pre-drilled holes if they are bolt on).
Old May 16, 2003 | 04:20 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Any 82-92 Firebird/Trans Am fender will fit, but the T/A's had 2 different styles of fender vents. The 82-84 had a larger vent which was made smaller in 85-90 so it wouldn't be covered up by the 85-up ground effects. If you want originality you'll need 82-84's but if you just want a matched pair, any year will do.
customblackbird
Aug 15, 2021 10:16 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
reiderz iroc
Aug 13, 2015 04:57 PM
