Headlight Motor Woes
Old May 24, 2003 | 07:49 AM
black88ta's Avatar
Car: 1988 GTA
Axle/Gears: 3.27:1
Hello,
I think my headlight motors are starting to go, but maybe it something else. When I turn them on, the spin and spin and spin, but the headlights barely come up, and usually never fully park, and then fall back down. Then when I just turn my parking lights on and off the headlight motors start spinning, but they are going down, as if I had my headlights on.
I am wondering if the headlight switch is bad or the motors are screwed up. I did not have gauge lights when I turned on the switch, so I just ran a 12v ignition wire to them, so now the turn on when I key the ignition. Anyone else ever have these problems?
Thanks,
Jason
Old May 24, 2003 | 09:20 AM
scauffiel's Avatar
Do a search on "headlight" and you'll find all kinds of answers.
S.
Old May 24, 2003 | 10:59 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
My headlight repair kit will solve your problem.
Lon Salgren
Top-Down Solutions
Old May 26, 2003 | 01:13 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
The headlight repair kit will indeed solve that very problem. I just purchased one from TDS and it was extremely easy to do the work.
The problem with the headlight motors actually has nothing to do with the motor itself. They are actually really reliable. The worm gear isn't the problem. It's those stupid delrin rod things. They turn to dust after awhile. Then the gear that turns the pin that raises and lowers the headlight is free to move around. This causes the worm gear to slip and not turn the assembly. Which in turn causes your headlights not to raise and lower properly.
Some people don't mess with it to much. Especially people who don't know squat about the cars. They either raise them manually or they buy a whole new motor assembly from the dealership and have them install it. What
It is a really easy repair. The instructions from Lon's kit are real easy to fallow. If I had known how easy it was going to be to fix my problem I would have bought the kit along time ago.
$18.00 for the kit, or $35.00 a motor on Ebay. Don't even ask what the dealer cost is. You might have a heart attack.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
stalkier
Aug 13, 2015 12:59 PM
