door locks will they fit??
Old Jun 10, 2003 | 05:58 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
will the door locks from a 92 Rs fit an 86 Z28?
if so how are is it to change them?
any pointers or tips?
thanks
Old Jun 10, 2003 | 10:38 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Are you talking about the lock cylinder? Because I believe all thirdgens have the same lock cylinder. I pulled a couple off an 82 (IIRC) T/A and they work on my 89. I only replaced one though. Locksmith charged me $15 to rekey it.
To replace it, you gotta take apart your inner door panel, then pull the retaining clip, remove the lock rods, and then remove the lock.
Installation is the reverse of removal (haha don't you hate the Haynes manual?)
Old Jun 11, 2003 | 07:37 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Yea im talking about the whole lock cyclinder part.
ok thanks for the help.
Old Jun 11, 2003 | 08:05 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
have fun taking doors apart ! hehe
Old Jun 11, 2003 | 10:01 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
what is that about?? is it really that hard?
while im in there i might as well replace the weathing stripping right?
Old Jun 12, 2003 | 12:14 AM
89V6FBIRD's Avatar
You're gonna need a couple of torx bolts and a flat screwdriver. Remove the armrest, remove the door handle trim thing (gotta remove the lock from the rod) then remove the actual door panel w/ the screwdriver, they just popout from the plastic rivets.
To remove the cylinder, you need pliers or some sort to push the retaining clip forward.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
