Fenders
Car: Z28 / 1982
Engine: 305 (LG4) Stock
Transmission: TH350
16 bolts ok thanks...
But how it's bolted in the lower corner right before the door ?
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I think it depends on whether or not you have gfx. Mine had a tab that sticks down under the car, that has a bolt on it, then my gfx had two nuts holding them on. I got to them from inside the door, but if you remove the inner fender, you can get to them as well.
Car: Take
Engine: Your
Transmission: Pick
You have to remove the fender liner. There will be several nuts holding the ground effects to the fender if you have them. There is also one large bolt that bolts the bottom rear of the fender. Like mentioned before, its on a "tab". You will also have to unbolt all the top bolts including the hood hinge. There are also 3-4 bolts going from the front of the fender to the front fascia. there are also pencil braces that bolt the bottom front of the fender to the body. You should be able to see all of this when you remove the fender liner.
morrow
Jan 13, 2024 12:29 PM
