Front Passenger Seat Belt Bracket
Old Jun 26, 2003 | 11:20 PM
Carbonsteel's Avatar
Does anyone know why I can't get the front passenger seat belt bracket off. It's held on by a torx bolt and doesn't want to come off.
I've recently began restoring a a 92' RS and the entire harness has to be replaced.
Is the torx bolt holding it on to the floor a left handed twist??
Anyone with any previous experience and advice would be greatly appreciated.
Thanks,
C
Old Jun 26, 2003 | 11:39 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
It's a regular thread, just need to use the right size torx and a ratchet... I had the same fun with the the back seat ones..
they glued in cause they go through the body..
Old Jun 27, 2003 | 12:07 AM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
It sould come off by turning it to the left there a real PITA but yeah thats how they come off.
Old Jun 27, 2003 | 12:33 PM
RPM WOT L 98's Avatar
If the torx is stripped, the use Vise Grips on the outside of the head, regular thread. BTW the torx size is 50, make sure that's the one you're using before you put pressure on it, also keep the ratchet straight and put pressure on it from the top. The main thing I found that helped was to put the bit into the screw and literally tap it in with a hammer bc sometimes they just don't make full contact unless you tap them in. Go slow on those, they are tight all the way up and too easy to strip.
Old Jun 27, 2003 | 06:02 PM
waltersb's Avatar
The rear seat bolts are all torx 45 on my car...
fronts are 50?
Old Jun 28, 2003 | 02:44 AM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
they are all 45
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
