Headliner Repair for the Do-it-yourselfer
Old Jul 12, 2003 | 07:04 AM
SlowMaro's Avatar
DONT!!!!! especially on ttops, maybe some of you are good at arts and crafts, other like i make a total mess and wish they had left it drooping.
i seriously wish i had digital pics of the carnage. this is horrible, ..well not HORRIBLE but, well, ..lets just say those 90 degree turns --on t tops-- is a biotch. i cut the material too short, showed bare edges of foam, now i have a patchwork job.
however with the t tops on it looks great! heh.
i know theres aplace who sells the t top headliner foam thats covered in any color you want, i just cant remember the web wite --help?--
it is also a bit pricey, 220 i believe. --said screw that-- places also do the headliner here for 200 bucks, also...screw that.. i guess ill just leave the headliner on this time and leave massive slack and tuck tuck tuck.
i thought it would be a good idea to take the headliner off and do it, which yes, its the only way unles syou want spray adhesive all over the place but yeah. i gotta figure a way around gravity for that one. perhaps just flipping the car over would work?? BLAH
ill get pics of this horrid job asap , someone has to laugh at my misfortune and LEARN!!!! shell out the 100 bucks its worth it.
then again if you were willing to do that, you wouldnt own a thirdgen. oh well.. thats my Moronic job of the day.
Old Jul 12, 2003 | 07:09 AM
Cargasm's Avatar
Jeez... mine came out great, and for less that $30, as did my homemade sunshades. 'Course, I used to work in an upholstery shop.
Old Jul 12, 2003 | 07:29 AM
SlowMaro's Avatar
lol i called around, and found a guy who will do it for 125 bucks.... rip off, heres how you kno wyou are getting screwed, ...its 50 bucks less if i take the foam out myself....
roflmao hahahahaha 50 bucks to install FOAM , 5 mins install omfg hahaha even funnier, 75 bucks for two yards of walmart cloth. heh. looks like im buying 2 more yards and going at it ONE more time....this time, im going for the good ole *tuck it under the plastic pieces, No one will see!!" method.....--still laugfhing at 50 bucks labor--
by the way, i had the chance to get that EXACT car you have....tan top though. flawless gorgeous car, one problem, ran like a raped ape and had 250,000 miles on it and was 6k!!!!
needless to say, i got my camaro for 3300 flawless 90k and happy about it lmao
Old Jul 12, 2003 | 11:31 AM
Cargasm's Avatar
Yup... mine's got a tan top as well. I'm very happy with it,, even though it only sees about 250 miles per month.
Old Jul 12, 2003 | 01:04 PM
CaysE's Avatar
$125 for a headliner job isn't all that bad. The majority of the cost is in labor, not materials. The adhesive, fiberglass patching, and headliner material probably costs about $20-$30 all together. Taking out the headliner is NOT a 5 minute job. You have to remove a number of trim pieces and the visors, not to mention an overhead console if you have one, and usually end up needing to replace clips as they break. Once the headliner is actually off all the clips, it takes 5 minutes just to get the damn thing out of the car without snapping it in half. The patch work has to be done first and dried so the board is stronger, then the adhesive and material have to be applied at the same time in small strips. It's a pain in the ***, believe me, when you only have two hands. And that's for a hard-top car... I haven't even attempted my t-top headliner yet. Throw on drying time for the adhesive to cure (about 12 hours), and then you have to reinstall it.
Bottom line, this is not an easy task when you do it right. Go spend the $125; it's worth it if you don't have the means necessary to do it right yourself. Read my posts here if you want more information: https://www.thirdgen.org/techbb2/sho...hreadid=127525
Old Jul 12, 2003 | 01:51 PM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
My theory - if you're going to spend $125, just shell out $170 and get a pre-covered ABS board. That way you don't have to worry if the old headliner breaks when you remove it.
Old Jul 12, 2003 | 09:52 PM
RPM WOT L 98's Avatar
Amen. I did, haven't looked back since. Well actually I can't stop looking at it, an excellent product. I wouldn't dream of recovering the stock fiberboard, it would break and look not half as good if I did recover it, and then during install it would break again and I'd throw it out and buy the ABS headliner anyway.
Doing a headliner is a PITA, period. It really helps when you eliminate things that can go wrong and ruin the whole project. Spend the $159 and get the good stuff, and never have to worry about it again. IMO.
Old Jul 13, 2003 | 03:57 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
where do you get the aftermarket abs t-top headliners?
Old Jul 13, 2003 | 05:12 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Thanks goodness home-ec was a required class in my middle school. My headliner turned out pretty darn good.
As for ABS boards.
http://www.yearone.com/serverfiles/h...sp?hid=G11AB20
http://www.hawksthirdgenparts.com/in...il?v=1&pid=536
http://www.thirdgenresource.com/inc/pdetail?v=1&pid=516
Old Jul 13, 2003 | 07:07 PM
thanks !!
Old Jul 13, 2003 | 10:55 PM
SlowMaro's Avatar
you know, thats funny as hell, cause it literally only took 5 mins to remove he old headliner board, without breaking it, and i put it back in, in 5 mins, without breaking it....if it takes you longer than 10 mins to remove a headliner board, you prolly shouldnt own a camaro, in any event the guy said hed do it for 70 bucks if i took the headliner board out myself.....so uh , guess ill do that.
i used to build complex speaker boxes for a living and had to carpet them, way harder than a headliner, but it was also CARPET, you can fix errors in carpet very easily due to it being semi plush, ..hard to patch up material that is damn near see through to begin with....
Old Jul 14, 2003 | 12:29 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I just ripped mine out for now. Looks bare, but I haven't figured out yet just how I want to attack the problem.
Shows a nice color of the original paint though.
Gotta get my door hinges done first.
Old Jul 14, 2003 | 12:38 AM
SlowMaro's Avatar
yeah i noticed how nice the original paint looked when i took mine off. i was like "damn"
Old Jul 14, 2003 | 07:56 AM
Car: 1989 Firebird
Removing the headliner makes you want to get a new paint job the same day, huh?
I had a new ABS headliner on order and got so fed up with my old one, I just ripped it out. It was nice looking at the metal for a while with the paint that great.
Old Jul 14, 2003 | 08:09 AM
bigals87z28's Avatar
Car: Check The Sig
yea, im deff gunna get a ABS headliner so i can just tear the chit out of the old one... I have several questions...
1) When you break the clips off, can you get them at a parts store?
2) Is the center consol hard to remove? I have the article, but they dont say "ah this is a biatch to remove" or "this is CAKE".
3) Trim parts... can i get clips for thoes or do i need to be careful.
4) Would black headliner look good in my car? I think im gunna go half and half with my dad on an all black hawks deal with visors, headliner, and sail pannels etc. i think a black headliner would look good, but i could go grey again to keep it stock... thoughts?
Old Jul 14, 2003 | 11:04 AM
al, take your time, go slow and try not to break any thing you don't have to. any one with a basic under standing of gm engineering will take to this easily. console is easy. never needed to go out for missing or broken parts. took the headliner in and out of my white camaro 3 times-no prob. did my black iroc by cutting it. fast but messy-have a carvac handy if you cut it. you'll have to take down most of the trim to get at the corners anyway so it may be easier to just do it right to start with.
keep it stock-grey rocks
i have a new zz-4 cam for sale if you're interested-mike
Old Jul 14, 2003 | 11:44 AM
Car: Check The Sig
yea, my stock one is already falling apart and it sucks that i cant take off my ttops or all that fuzz will fly around and get in my eye... plus it looks UGLY as sin.. I have screen door screen holding it all together right now and duct tape.. its very ghetto fab right now..
Old Jul 14, 2003 | 11:48 AM
Car: 1989 Firebird
1) Which clips would these be? The two clips near at the front of the headliner? The ABS boards don't need them. I actually saved the clips off my stock headliner board, thinking I might attach them to the ABS one, but it stays in well enough without them.
2) Not sure about that. Although, if you take your time, it shouldn't be that bad.
3) If you mean the clips on the A-pillar molding (white Christmas tree ones), I've actually seen them in some catalogue. Of course, being careful is the best way to do it.
4) Up to you. I personally like stock.
Good luck with it all.
Old Jul 14, 2003 | 01:11 PM
al, how did it get that bad? go find a sturdy pair of sissors and cut it right NOW! that stuff is cancerous. besides it's a t-top day here in jersey.
Old Jul 14, 2003 | 05:31 PM
SlowMaro's Avatar
lol i used liquid nails to stick the headliner back on for one reason. its thick and sticky...worked well i might add. if i ever need to take it off this will more than likely present a problem, this is where i will get the abs one...
Old Jul 14, 2003 | 08:20 PM
Car: Check The Sig
is it really? holy chit... well my cars been in the garage since there is no exhaust (see sig). Wow, i didnt know that... Well, my car was my dads first. He bought it new in 87. After around like 93, he kinda just left it in the garage and it sat there untill i awoke it from the garage. After i got my license i started making money for tune ups and stuff like that... now its my car and i pump the money into it now hehe. It really sucks when i cant take off the ttops to cruse down to toms river for meets. PM me and ill fill you in on some of our meets on rt. 37. We are having a meet at etown on the 25th. Come join us crazy ****'s!!!
Old Jul 14, 2003 | 08:27 PM
cancerous, no. not really. i was just trying to motovate you. i work nights so i really don't get out to cruise much. are you interested in my zz-4 cam?
Old Jul 14, 2003 | 08:36 PM
Car: Check The Sig
nah thanks man... i got on sitting in my garage right now... thanks for the modivation! but i need to get my hooker on ... its being a biatch.. nothing a few hundred clamps cant solve! I hope to get the headliner soon.... my dad said after the car looks good he was gunna get one as a present for the car... doubt that. Hes said that about 100 times... oh well... i wana rip it off, but im afraid about the center part.
Old Jul 14, 2003 | 08:57 PM
just cut the headliner in front and behind the console. the console comes out easy with some needle nose pliers to remove the retaining clips. you wount believe how much better it will look !!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
