92 gfx
Old Aug 12, 2003 | 08:47 PM
_max_'s Avatar
92 gfx
my car has never had gfx and when at the bone yard i got gfx off a 92z and well the **** had a bracket welded to the side of the car well the question here is there a substitute antother type of angle to your car to mount the gfx
Old Aug 13, 2003 | 07:40 AM
_max_'s Avatar
btt
Old Aug 13, 2003 | 01:55 PM
MikeC.86Roc's Avatar
I am guessing you are referring to the bracket that holds the pieces under the doors. And yes, you are right, there is no way to fasten it if you have a sport coupe type car or one that never had any F/X at all. You might be able to weld the bracket if you cut the one out of the donor car, but talk about a major hassle...
Old Aug 13, 2003 | 02:13 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
You can buy that bracket from Classic Industries for like $35 or so. Just get their Camaro (or Firebird) catalog.
Old Aug 13, 2003 | 06:38 PM
_max_'s Avatar
dern prolly gunna have to drill them buggers of the donor and re-weld to my car GTA-SPD thanx for the tip on classic i e-mailed them today see what kind of reply i get
Old Aug 13, 2003 | 08:27 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
You can attach the rocker panel gfx to your car without the bracket on the SC. It will hold up fine as long as noone steps on the gfx. Use 1/4 long metal screws under the gfx where they are suppose to go and drill the 2 small holes in the fender for the emblem area, then drill the hole in the rear quarter panel for the stud in the gfx to go into the int where it will be held on by the wing nut.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
snakeshooter
Sep 7, 2015 11:15 AM
LittleFranks
Aug 20, 2015 03:55 PM
