Front Nose swap question
Old Aug 15, 2003 | 10:08 AM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I have an 89 formula, and I'd like to swap out the front nose on it for a 91-92 nose, I know I'll need the Nose, the impact absorber, and parking lights, my question is will I need Headlights from a 91-92?
Old Aug 15, 2003 | 11:23 AM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
yes you will, i think the lights themselves are a little different and i know the bezels are different
Old Aug 15, 2003 | 12:00 PM
Engine: Mild 350
Thanx, I appreciate it, I figured I need the lights too.
Old Aug 15, 2003 | 12:05 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Are you doing the ground effects as well? The nose would look kinda strange without the rain-gutter 91-92 side skirts.
Old Aug 15, 2003 | 02:59 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
It won't look strange if he buys a 91-92 Formula nose. The 91-92 Formulas didn't have ground effects.
Abird4U2nv1: you might consider putting a 91-92 Formula rear bumper on as well, or when you're done you'll have the black plastic trim strips on the 89 rear bumper and not the 91 front- might look weird. By the way, I did the swap and yes you need the lights.
Old Aug 15, 2003 | 03:33 PM
Engine: Mild 350
THANX FOR ALL THE HELP GUYS, I APPRECIATE IT
Old Aug 16, 2003 | 12:40 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
you could keep the headlights as is!..and just trim the lower lip of the bezel and shave the bottoms humps off the nose and it should all fit proper!
and if you want ,you just add some 82' front end ground f/x and will look fuller and more trimmed down like mine!
Old Aug 17, 2003 | 11:43 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
No way man! This is JMatlock88's car:
Old Aug 18, 2003 | 06:17 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
It would look strange on a 1985-1990 Trans-AM. Not on a Formula of any kind.
Old Aug 20, 2003 | 06:20 PM
logikal6785's Avatar
hehe doesn't matter what you put it on, it'll look wierd. just get an 85-90 nose and strap it on =D
i'm jk, first car was an 89 GTA so ya i'm a little biased
power to you if you can do the swap man
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
