power windows slow
Old Aug 24, 2003 | 11:29 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
power windows slow
is it just me or all the motors seem to be slow? Mine take forever to go down, do i need a new motor for it?
Old Aug 25, 2003 | 08:33 AM
33now48's Avatar
My windows are slower than my other cars but this weekend I replaced the motor and it's much better. The driver side window gets used alot and it started getting slower and slower. It then started stopping while moving up or down. Finally it would move only an inch or so. But instead of removing the entire regulator assembly, I removed only the motor.
After removing the trim panel and with the window fully up & wedged, I located the rivets (3) holding the motor to the regulator (feeling the back of the motor housing, I felt three bumps). Two of the rivets could be seen but unfortunately, I couldn't get to the rivets without drilling through the door. I used a 3/8 or 1/2 inch drill bit to drill through the door. I could then see the rivets. Using a 3/16 inch drill bit, I drilled out the rivets. The motor easily came out the front access hole. The replacement motor came with the slotted head bolts and nuts. I used medium strength loktite to keep the nuts from loosening. I inserted the screw driver through the drilled hole and needle nosed pliers on the back to hold the nut. It took about 1 1/2 hour but the next time will probably take 30 minutes. The local dealer quoted $300 while the lifetime motor cost less than $50 at a major chain parts store.
Old Aug 25, 2003 | 12:42 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
The most common reason for slow window motors is lack of lubrication. You can add medium to heavy grease to the window tracks, as well as the arms, etc. If the lube doesn't help, then most likely the window has been run dry to long, causing the motor to be on the way out. These windows are a heck of a lot slower than most windows I've had in the past anyway, but a quick lube job made mine quite a bit quicker than when I first got the car.
33now48, got a part number for the motor-only assembly? That might come in usefull...
Old Aug 27, 2003 | 07:09 AM
33now48's Avatar
I got the replacement motor from AutoZone. It is Siemens WL42000 and has a bar code number of 53674 42000.
Old Aug 27, 2003 | 09:03 AM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
How much?
Old Aug 27, 2003 | 09:33 AM
33now48's Avatar
$42.95 plus tax. It wasn't difficult at all and since I didn't remove the regulator, I didn't have to worry about the couterbalance spring and re-aligning the window.
Old Aug 30, 2003 | 03:49 AM
MdFormula350's Avatar
i did the same thing as 33now48 did and my window has been working great now for 1 year +. i hardly used any type of lubricant other than some sort of graphite stuff my grandfather had sitting around.
u be surprised what kinda stuff u find at the bottom of a door, i found two screws and some small pebbles.
cant wait to do my drivers side window motor, its showing the same signs my passengers side did, not just there yet; i like to wait untill the window completely stops moving, makes its more fun.
Old Aug 30, 2003 | 05:07 PM
RySeyes's Avatar
My friend just had the same problem with his '92 RS. Like they said, motors.
Old Aug 30, 2003 | 08:41 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
Well, me thinks that I will have to be going that route shortly as well. *sigh*
Old Aug 31, 2003 | 08:08 PM
Kandied91z's Avatar
is it possible to use other vehicle motors...possibly ones that are faster? granted the glass is quite large but there must be some motors out there that work better.
also, what's the hardest part of replacement? how do you re-rivet the motor back in? i don't want to have to drill holes through everything to remove my motor.
Old Sep 1, 2003 | 03:43 AM
RSRagtop's Avatar
How about 4th gen motors?
Old Sep 1, 2003 | 07:30 PM
2 dope's Avatar
Engine: 305 LG4
in response to finding things in the bottom of the door, i found something under the carpet on my car, a big spliff LOL.
Old Sep 3, 2003 | 07:27 AM
33now48's Avatar
Kandied91z - If you want to use rivets, I believe you would have to remove the entire regulator assemb., remove the motor from the regulator and then rivet the new motor to the regulator and then rivet the regulator to the door. I didn't want to do all that. On my 91 Camaro, drilling three small holes (about 1/2") was no big deal and saved a lot of time & frustration. I was a little concerned about the bolt & nut getting loose so that's why I added a little lok-tite. Good luck.
Old Sep 7, 2003 | 05:02 PM
xChRiSx's Avatar
Im gonna have to take my door apart sometime.... dropped a cd inside it and the window bends the cd every time its rolled down.... im sure i got lots of crazy stuff inside there.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
