HELP! WHATS RATTLING!!! Please!
Old Aug 25, 2003 | 07:30 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
I have a rattle when I go over bumps. Judging bythe tone of it, it sounds like it is some kinda strong metal (Not the rods going to the locks/handles) Its either in the door, or right behind it (In the speaker area)
I had the door panel off yesterday. There is nothing loose in/on the door. I padded everywhere those rods could rattle against the door metal. and it still there. I checked to make sure the speaker wasnt to deap hitting the body panels behind them, they are fine.
I am almost POSITIVE that its not the door handle, its a little loose but not bad, my friends 89 has a loose door handle and it sounds different.
What else is in the area that could be loose. I was thinking maybe the latching mechanism on the door, but I couldnt move it with a screw driver so I dont suspect that.
Any Help?
Old Aug 25, 2003 | 05:01 PM
Screamer27's Avatar
Car: 1986 Monte SS / 1988 Iroc-Z
Engine: LS3 / L98
Transmission: 4l80E / T56
Axle/Gears: 3.73 / 3.45
This is a shot in the dark, but do you have power locks, it might have something to do with the lock mechanism, or anything dealing with that inside the door.
Old Aug 25, 2003 | 09:15 PM
Dean92RS's Avatar
Car: surprise!! a '92RS!!!
Transmission: 5 speed "M39"
Striker plate!!!
I liked your description of the noise---"strong metal".
That's exactly like what the door latch sounds like hitting the striker, and these cars do it all the time.
I dunno if the '86's had them, but my '92 has these striker pads on both the door and the doorframe. They have a slight angle to them, and are identical, but mounted 180* opposite, so as the door closes, they lock up against each other, bracing the door.
They're about 3/4 inch wide and 1 1/2 inches long. Go look at a 90's thirdgen, near the top of the door, if yours doesn't have 'em.
Wish I knew how to draw online!
GM used plastic spacers for shims to force these together, but you can use anything, believe it or not I used cardboard the first day I had the car at work---it worked for awhile. You could cut pieces of an old innertube---just about anything to shim these out. That will take the load off the striker and I'll bet it will get rid of the clunk!
jrdturbo
Mar 31, 2016 02:58 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
aaron7
Aug 26, 2015 09:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
