Hatch Will Not Latch??
Old Aug 31, 2003 | 03:21 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
My car has a power hatch and the other day it was acting funny. When I popped it open before I could go around to lift it, the motor would bring it back down. I finally got it open and I realized that my rear compartment light was stuck on. So I lift up on the hatch and its not even latched. How can I fix this?? I think the motor retracted but hasnt come back up because theres nothing in it. Any ideas???
Old Aug 31, 2003 | 05:51 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hehe, if you look down through the latch in the back there is a black "button" use something to press it down and the motor will come up
Old Aug 31, 2003 | 06:50 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Thanks alot!!! I knew it had to be something little like that.
Old Aug 31, 2003 | 07:06 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You also need new hatch struts if you have to lift the hatch by hand.
Old Aug 31, 2003 | 07:29 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I suspect the hatch pull-down unit has cycled part way down without the latch catching on the hatch hook. To re-set the unit, press and hold down the small black switch next to the latch until the unit has cycled down fully. Then release and it will cycle back up fully. If the switch doesn't cause the unit to lower or acts sporadically it needs to be replaced. Bad news is GM has recently discontinued the striker-sensing switch. Without new ones available OEM, the best source would be a good used one.
Lon
Old Jan 13, 2008 | 08:43 AM
dj_justice's Avatar
Car: 91 Formula Firebird
Transmission: 4l60
Re: Hatch Will Not Latch??
Does anyone have a picture of this small black switch? I cant seem to find it.
Old Jan 13, 2008 | 04:00 PM
lonsal's Avatar
The picture is of teh entire striker-sensing switch which includes the wiring for the pull-down unit. The actual switch portion is shown in the loser right-hand side of the picture. The black paddle you see sticking down is the switch that needs to be pressed. It is attached just in front of the latch with a single hex-head screw. There are 3 wires coming out of the switch, black, orange and white.
Lon
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
