attaching door fabric to upper trim
Old Sep 9, 2003 | 06:51 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Like many others trim piece, that is right under the window inside the car, mine cracked. I bought another one to replace it. What sort of adhesive should I use to attach the new piece?
Old Sep 9, 2003 | 08:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Could you repeat the question? I'm unsure about what you're asking.
JamesC
Old Sep 9, 2003 | 09:18 PM
demonchild's Avatar
i know what hes talking about. if you look at the plastic piece, there should be stems for the speed nuts to bolt onto. look at you door panel when you get it off. also, do a search on how to get it off...there is some really good explanations.
Old Sep 9, 2003 | 10:08 PM
Car: 92' RS
Engine: LO3
Oh its bolted I though that it was adhesive.
James C: The piece I am refering to is the one at the very top of the door. I often use it as an armrest. It runs the entire length of the door. Its black, plastic.
Old Sep 9, 2003 | 11:29 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i know what ur talkin about and the only way to put the fabric on the plastic is with plastic rivits, becuz thats how its held on, u could try using regular rivits and see how that works but u might crack the plastic
Old Sep 9, 2003 | 11:55 PM
Car: 92' RS
Engine: LO3
Plastic rivets, huh, never knew such a thing existed. Do they still work in the standard metal rivet guns?
And where would you find such a creature? Hardware store?
Old Sep 10, 2003 | 12:22 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah metal rivits will work, u can get them at like homedepot or lowes or any place. some places sell a kit with the rivit gun and a bunch of rivits.
i think the plastic "rivits" are molded into that plastic piece and i guess GM used some sort of heat gun/press thing and like made them look like rivits when the fabric was "rivited" o the plasitc
Old Sep 10, 2003 | 12:24 AM
Car: 92' RS
Engine: LO3
I already have a rivet gun with some steel and Aluminium rivets. I was just wondering if plastic rivets would work in the same gun as the metal ones or if they used a different gun or different method completely.
Old Sep 10, 2003 | 12:32 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'm at a loss about the fabric and plastic part (probably because I'm stupid or something) but, the plastic is attached to the doorpanel with 10mm stamped thread cutting nuts. They are put on reverse of normal. I used a pair of 'duck billed' pliers to tighten mine back down (and it was slightly a pita)...
Old Sep 10, 2003 | 12:34 AM
Car: 92' RS
Engine: LO3
Thanks deadbird, thats exactly what I wanted to know
Old Sep 10, 2003 | 09:01 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
oh that part, i thought u were talkin about the fabric piece by the window
1992 Trans Am
May 10, 2023 07:19 PM
billybob6110
Sep 23, 2015 01:30 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
